[mapguide-users] Silverlight/Moonlight Viewer
alucas alucas at svl.es
Fri Feb 20 12:57:56 EST 2009
It's the first time that I see this thread. We are using both mapguide
enterprise/open source since the first official version (2007/1.0). We've
tested both viewers (DWG and AJAX) and we're using AJAX viewer because in
som administrations ActiveX plugins are a security problem. So, my question
is if is the mapguide (with AJAX viewer) more slowly than other servers? If
I configure the same project with mapguide and the ajax vierwer and
MapServer is mapguide more slowly? I know Mapguide 6.5 and I'm agree with
Carl, accessing through internet (low bandwith) the activex viewer is
faster. When the application is running in LAN, I don't see any difference.
Carl Jokl wrote:
> The viewer and the performence of it has continued to be an issue for us.
> We were backed into a situation where we had to continue using the DWF
> viewer because it was the only viewer capable of delivering the
> application we develop at a usable level of performance on MapGuide 2009.
> I myself am not at liberty to make decisions as to what I am assigned to
> work on. If there was work being done on a new viewer in the community it
> would not be unreasonable for our organisation to help in the development
> if it potentially made the difference between being able to migrate from
> Mapguide 6.5 to 2009. If the new viewer is just an idea which was never
> developed then at least I know what became of that. I suspect that the
> viewer is probably just going to be one of a number of issues which would
> need to be overcome in order to make MapGuide 2009 workable for the
> project we are trying to use it for.
View this message in context: http://n2.nabble.com/Silverlight-Moonlight-Viewer-tp1812471p2360348.html
