[mapguide-users] permissions to users in the admin site
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Mon Jul 6 09:51:31 EDT 2009
You can set permissions on items using a tool such as Maestro or Studio.
I would not recommend doing so, as it is very difficult to do so.
To display a map, the user must have read access to:
* The weblayout
* The mapdefinition
* Every layer in the map
* Every featuresource referenced by the map layers
Denied access will prevent the map from displaying at all.
On top of this, the entire path to the resource must grant access.
Eg.: Library://Folder1/Folder2/Resource.Extension
The user must be granted read access to Folder1 AND Folder2 AND Resource.
If you deny access to say Folder1, access to Folder2 and Resource is denied,
regardless of what access you set on them explicitly.
Regards, Kenneth Skovhede, GEOGRAF A/S
T.kiran kumar reddy skrev:
> Hi to every one,
>        when i entered into administrator login(
> http://localhost/mapguide/mapadmin/login.php )there we can create some users
> with different permissons (administator or map author). if we create a user
> with map author permissions only what are the things he can get ? what are
> the uses if we create with mapauthor only? is there any method to restrict
> user to use perticular specified packages only not all in the server
> packages .If any body kows about these questions please help me
