[mapguide-users] SQL Server Data not appearing in Fusion
Berdel, Brian brian.berdel at mcmtrans.com
Tue Jul 7 15:44:36 EDT 2009
May be something with Apache then and fusion then, checking that log may help.  It does work with IIS.  Also Firebug may have an answer....
Brian
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of kevin_t
Sent: Tuesday, July 07, 2009 3:33 PM
To: mapguide-users at lists.osgeo.org
Subject: RE: [mapguide-users] SQL Server Data not appearing in Fusion
That's good, at least I know it's possible to load it with fusion layout.
The fusion layout does load if the SQL Server data is removed from the map.
MapGuide Enterprise 2010 and SQL Server 2008 are on different servers.  Both
have installed:
Apache2
Windows Server 2003 R2
Berdel, Brian wrote:
> I am not sure if there is a bug, but I am able to load SQL Server 2008
> spatial data into fusion with mapguide 2.0.2 and 2.1 beta and Enterprise
> 2010.  Using IIS XP and server 2003/ 2008. Does the same map load in
> fusion if you remove the data?
> Brian
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Paul Spencer
> Sent: Tuesday, July 07, 2009 1:54 PM
> To: MapGuide Users Mail List
> Subject: Re: [mapguide-users] SQL Server Data not appearing in Fusion
> can you check your apache error log.  I expect it is a bug in Fusion's
> php code.
> Cheers
> Paul
> On 7-Jul-09, at 1:51 PM, kevin_t wrote:
>> Hi all,
>> I have a problem where my map in a fusion/flexible layout doesn't
>> load in my
>> browser if I have data from SQL Server 2008.  It loads fine in the
>> basic
>> layout, so it is unlikely that it's a SQL Server issue.  I am using
>> MapGuide
>> Enterprise 2010 with SQL Server 2008 Trial version.  The browser I
>> tested
>> are Firefox and IE.
>> My steps are as follows:
>> - Import shapefile to SQL Server 2008 using SQL Server 2008 Spatial
>> Tools.
>> - Create a data connection in MG Studio 2010 to it with the OSGeo FDO
>> Provider for SQL Server Spatial.
>> - Create the layer and add it to a map that is referenced by a fusion
>> layout.
>> - View the layout in a browser.
>> Does anyone know if this is a bug with fusion layouts and if there
>> is a
>> workaround?
>> View this message in context:
>> http://n2.nabble.com/SQL-Server-Data-not-appearing-in-Fusion-tp3220760p3220760.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Important notice to recipients:
> Copies of documents that may be relied upon by you are limited to the
> printed copies (also known as 'hard copies') that are signed and sealed by
> the Engineer and/or Land Surveyor. Files in electronic formats, or other
> types of information furnished by the Engineer and/or Land Surveyor to you
> such as text, data or graphics are for your convenience only. Any
> conclusions or information obtained or derived from such electronic files
> will be at the user's sole risk. When transferring documents in electronic
> formats, the Engineer and/or Land Surveyor makes no representation as to
> long-term compatibility, usability, or readability of the documents
> resulting from the use of software application packages, operating systems
> or computer hardware differing from those used by McMahon Associates, Inc.
> at the beginning of the project.
View this message in context: http://n2.nabble.com/SQL-Server-Data-not-appearing-in-Fusion-tp3220760p3221435.html
Copies of documents that may be relied upon by you are limited to the printed copies (also known as 'hard copies') that are signed and sealed by the Engineer and/or Land Surveyor. Files in electronic formats, or other types of information furnished by the Engineer and/or Land Surveyor to you such as text, data or graphics are for your convenience only. Any conclusions or information obtained or derived from such electronic files will be at the user's sole risk. When transferring documents in electronic formats, the Engineer and/or Land Surveyor makes no representation as to long-term compatibility, usability, or readability of the documents resulting from the use of software application packages, operating systems or computer hardware differing from those used by McMahon Associates, Inc. at the beginning of the project.
