[mapguide-users] SQL Server Data not appearing in Fusion
Paul Spencer pagameba at gmail.com
Tue Jul 7 16:05:27 EDT 2009
Seems like it could be a bug somewhere in Fusion and how it uses the
MapGuide API, there have been memory leaks found and fixed before
mostly related to using Feature Readers without properly closing
them.  You can increase the memory limit for PHP in php.ini which you
should find in an Apache folder under the WebServerExtensions folder
somewhere.
Paul
On 7-Jul-09, at 3:26 PM, kevin_t wrote:
>> From the Apache error log:
> "PHP Fatal error:  Allowed memory size of 67108864 bytes exhausted
> (tried to
> allocate 34674 bytes) in C:\\Program
> Files\\Autodesk\\MapGuideEnterprise2010\\WebServerExtensions\\www\
> \fusion\\common\\php\\Utilities.php
> on line 42, referer: <long URL to my fusion layout>"
> I opened the utilities.php and looked at line 42.  Nothing seems out
> of the
> ordinary.  I wonder where this "allowed memory size" setting is.
> I found a posting that describes someone having to increase PHP
> memory to
> get their fusion to work.  Is this related?
> http://n2.nabble.com/Unmanaged-Performance-td1818163.html#a1818163
> Paul Spencer wrote:
>> can you check your apache error log.  I expect it is a bug in
>> Fusion's
>> php code.
>> Cheers
>> Paul
>> On 7-Jul-09, at 1:51 PM, kevin_t wrote:
>>> Hi all,
>>> I have a problem where my map in a fusion/flexible layout doesn't
>>> load in my
>>> browser if I have data from SQL Server 2008.  It loads fine in the
>>> basic
>>> layout, so it is unlikely that it's a SQL Server issue.  I am using
>>> MapGuide
>>> Enterprise 2010 with SQL Server 2008 Trial version.  The browser I
>>> tested
>>> are Firefox and IE.
>>> My steps are as follows:
>>> - Import shapefile to SQL Server 2008 using SQL Server 2008 Spatial
>>> Tools.
>>> - Create a data connection in MG Studio 2010 to it with the OSGeo
>>> FDO
>>> Provider for SQL Server Spatial.
>>> - Create the layer and add it to a map that is referenced by a
>>> fusion
>>> layout.
>>> - View the layout in a browser.
>>> Does anyone know if this is a bug with fusion layouts and if there
>>> is a
>>> workaround?
>>> View this message in context:
>>> http://n2.nabble.com/SQL-Server-Data-not-appearing-in-Fusion-tp3220760p3220760.html
>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> View this message in context: http://n2.nabble.com/SQL-Server-Data-not-appearing-in-Fusion-tp3220760p3221403.html
