[mapguide-users] mapguide-google map integration
Nisha P nishap97 at gmail.com
Fri Jul 10 00:18:18 EDT 2009
 Hello Sir,
       Thank you for your valuable information..I will take care while
sending questions like
        that and specify my part..
Regards
Nisha
On Thu, Jul 9, 2009 at 9:46 PM, Jason Birch <Jason.Birch at nanaimo.ca> wrote:
>  Nisha,
> The response you received is entirely due to the way you asked the
> question.  There have been many cases where users come to this mailing list
> not having done any research, ask many vague questions, and expect the
> volunteers on this list to do their work for them.
> If you want good answers to your questions, show that you have done your
> part and provide as specific a question as you can.  In your case it would
> have been more useful to phrase your question something like:
> Hello,
> I have been trying to add a Google Maps layer to my (AJAX | Fusion) web
> layout using (MapGuide Open Source 2.1 Beta).  I have already looked in the
> mailing lists and found the following:
> http://trac.osgeo.org/fusion/wiki/MapGuideCommercialOverlays
> http://n2.nabble.com/re%3A-flexible-web-layouts-td2660073.html#a2660073
> http://enterprise.mapguide.com/googleflexslate
> However, when I try to add a Google Maps layer following these
> instructions, I still get this error:
> Here is the relevant part of my Application Definition:
> And you can see an example of my map here:
> Does anyone have an idea of what is wrong?
> Thanks,
> To put it plainly, if you don't take the time to write a good question on
> open source mailing lists, then you can expect hostility or just to be
> ignored.  More information on the art of asking good questions (good
> information, if a bit condescending):
> http://catb.org/esr/faqs/smart-questions.html
> In specific response to your question, even if you are running MapGuide 2.1
> Beta with a Fusion layout, you will likely run into problems with the
> commercial layers that have since been fixed in Fusion trunk.
> http://trac.osgeo.org/fusion/changeset/1842
> http://trac.osgeo.org/fusion/changeset/1847
> http://trac.osgeo.org/fusion/changeset/1864
> Unfortunately, to use these fixes you'll need to use SVN to download the
> latest Fusion.  More information on this on the Fusion wiki:
> Jason
> *From:* Nisha P
> *Sent:* Wednesday, July 08, 2009 8:50 PM
> *Subject:* Re: [mapguide-users] mapguide-google map integration
> If you can please help..other wise leave it..
> Thanks and Regards,
> Nisha P
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Nisha
nisha at iiitmk.ac.in
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090710/fb2feece/attachment.html
