AW: RE: [mapguide-users] MG Error Out of memory, bad allocation
juergen.konradt at bluewin.ch juergen.konradt at bluewin.ch
Tue Jul 21 11:23:35 EDT 2009
<Can you confirm if your TIFF files are tiled tiff? If they aren't then the system will be slow as it converts them on
the fly.
I will try to convert the files to tiled TIFF with MG Rasterworkshop (MG 6.5)
<How many tiles should be shown at the 1:2000 scale? I'm guessing this should only be a small subset and hence it
should be quick.
max. 4 files
<I think Stefan's suggestion is a good one, in particular for the ecw.
<What tool are you using to convert the files? Are people using FW Tools or something else?
created with ImageMagick, converted to jpg with Photoshop, to ecw with ER-Mapper
<Dave
Jürgen
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Stefan
Dalakov
Sent: Tuesday, July 21, 2009 6:30 AM
To: juergen.konradt at bluewin.ch; MapGuide Users Mail List
Subject: Re: [mapguide-users] MG Error Out of memory, bad allocation
Hi Jürgen
One of the options may be to merge together files.
I have an image, 32000x16000 tiled RGB tiff, 1.7GB in size which is
served like a lightning by an old computer, not even designed to be a
server, with 1.5 GB of RAM.
Software configuration - same as yours.
By merging rasters you can reduce the number of files almost 60 times,
which means that you will have 15-20 files, roughly.
Of course, you know better, if your project allows this, but in general,
MGOS seems to handle easier a small number of big files, rather than a
big number of small files.
Best regards : Stefan Dalakov
juergen.konradt at bluewin.ch wrote:
> Hi,
> I have a problem with a rasterlayer (not tiled).
> It is a layer using about 1000 TIFF-Files (RGB, 3000x3000 pixel, scale 1:1000).
> The visibility of the layer is 1:100 to 1:5000.
> If I load the map (sacle 1:2000) I get the error: Out of memory. bad allocation.
> If I reduce the number of tiff-files in the folder (500) I get no error but the map is loading very, very slow.
> If I change the format from tiff to jpg or ecw (all 1000 files) I get no error but the map is also very slow.
> I get the same error with Autodesk Raster FDO and OSGEO Gdal
> MGOS 2.02 or MGOS 2.1.0 Beta
> W2003 Server SP2
> IIS 6.0
> AjaxViewer (JSP)
> is there any solution for this problem?
> Jürgen
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
