[mapguide-users] Error on selection
Tom Lazo / Stygy tom.lazo at hotmail.com
Tue Jul 28 14:11:20 EDT 2009
Hi Dave,
Thanks for the answer.. But i've changed that before
max_execution_time = 240    ; Maximum execution time of each script, in
seconds
max_input_time = 240        ; Maximum amount of time each script may spend
parsing request data
memory_limit = 1280M         ; Maximum amount of memory a script may consume
i changed it when i have the new layer with 30k points problem.
Another idea plz?.
Thanks.
Tom
Dave Wilson wrote:
> What is your memory setting in your php.ini? You probably need to up it
> from the 2MB default to 256 or higher.
> Dave
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Tom Lazo /
> Stygy
> Sent: Tuesday, July 28, 2009 11:39 AM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] Error on selection
> Hi all,
> I'm trying to select more than 20k features and i get an fusion.ajax
> error...i checked mi error.log and i found this...
> <2009-07-28T12:23:37> 	Fusion Viewer	127.0.0.1	Anonymous
>  Error: An unclassified exception occurred.
>  StackTrace:
>   - MgFeatureServiceHandler.ProcessOperation line 83 file
> d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\feature\FeatureServiceHandler.cpp
>   - MgOpSelectFeaturesSpatial.Execute line 110 file
> d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\feature\OpSelectFeaturesSpatial.cpp
>   - MgServerSelectFeatures.SelectFeatures line 249 file
> d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\feature\ServerSelectFeatures.cpp
> Is there any selection limit ??.
> Thanks.
> Tom
> http://n2.nabble.com/file/u222842/warning.png   Stygy is not a living
> being!
> http://n2.nabble.com/Error-on-selection-tp3344788p3344788.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
http://n2.nabble.com/file/u222842/warning.png   Stygy is not a living being!
View this message in context: http://n2.nabble.com/Error-on-selection-tp3344788p3345012.html
