[mapguide-users] Error on selection
Dave Wilson dave.wilson at autodesk.com
Tue Jul 28 17:07:51 EDT 2009
I can replicate the problem in MGE 2010.
I would say it's a bug of sorts, likely related to feature reader stuff and how the data is requested/returned to the browser. The rendered selection completes, but the data portion fails after several minutes (like 8 in case of selection of 40,000 features) of the browser being pinned at 50%.
The amount of data being returned isn't that great as far as I know.
I can't recall but isn't there a way to limit selection in Fusion?
Dave
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Tom Lazo / Stygy
Sent: Tuesday, July 28, 2009 12:11 PM
To: mapguide-users at lists.osgeo.org
Subject: RE: [mapguide-users] Error on selection
Hi Dave,
Thanks for the answer.. But i've changed that before
max_execution_time = 240    ; Maximum execution time of each script, in
seconds
max_input_time = 240        ; Maximum amount of time each script may spend
parsing request data
memory_limit = 1280M         ; Maximum amount of memory a script may consume
i changed it when i have the new layer with 30k points problem.
Another idea plz?.
Thanks.
Tom
Dave Wilson wrote:
> What is your memory setting in your php.ini? You probably need to up it
> from the 2MB default to 256 or higher.
> Dave
> Stygy
> Sent: Tuesday, July 28, 2009 11:39 AM
> Subject: [mapguide-users] Error on selection
> Hi all,
> I'm trying to select more than 20k features and i get an fusion.ajax
> error...i checked mi error.log and i found this...
> <2009-07-28T12:23:37> 	Fusion Viewer	127.0.0.1	Anonymous
>  Error: An unclassified exception occurred.
>  StackTrace:
>   - MgFeatureServiceHandler.ProcessOperation line 83 file
> d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\feature\FeatureServiceHandler.cpp
>   - MgOpSelectFeaturesSpatial.Execute line 110 file
> d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\feature\OpSelectFeaturesSpatial.cpp
>   - MgServerSelectFeatures.SelectFeatures line 249 file
> d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\feature\ServerSelectFeatures.cpp
> Is there any selection limit ??.
> Thanks.
> Tom
> http://n2.nabble.com/file/u222842/warning.png   Stygy is not a living
> being!
> http://n2.nabble.com/Error-on-selection-tp3344788p3344788.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
http://n2.nabble.com/file/u222842/warning.png   Stygy is not a living being!
View this message in context: http://n2.nabble.com/Error-on-selection-tp3344788p3345012.html
