[mapguide-users] Non-Administrator Users Can't Login
Dave Wilson
dave.wilson at autodesk.com
Wed Jul 29 10:41:30 EDT 2009
In order to use MapGuide Studio (I'm not sure about Maestro) you need the Author role to login and edit/manage resources. Author's cannot log into the Site Admin web page.
Administrator has full rights.
Having neither of the two roles the login is just a user and has permissions on resources as dictated by the permissions in Site Explorer in Studio (or Maestro).
Regards,
Dave
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kenneth Skovhede, GEOGRAF A/S
Sent: Wednesday, July 29, 2009 1:41 AM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Non-Administrator Users Can't Login
You can manage users from the MapAdmin:
http://localhost/mapguide/mapadmin/login.php
These users can then log in to MapGuide.
You need to set their permissions to resources
with a tool like Maestro or Studio.
There are no execute permissions in MapGuide, only read and write.
The permission system is not really documented, and works the opposite of what I expected.
Search the mailing lists for details.
Regards, Kenneth Skovhede, GEOGRAF A/S
Bloozitis skrev:
Hi Mauricio,
Could you please be so kind as to explain, in detail, what these permissions are? Currently, I have set up a test account and a user account on the workstation with read and execute permissions. Unfortunately, there is no mention in the documentation of what permissions users need to access this.
Cheers,
Dennis
From: Mauricio Villablanca (via Nabble) [mailto:ml-user+109705-477115064 at ...<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=3334926&i=0>]
Sent: Thursday, July 23, 2009 1:08 AM
To: Dennis Soper
You need to set the right permissions of the repository folders.
Bloozitis wrote:
I've created a test user, assigned it to a "mapauthors" group I created, which assigns the user to the "Authors" role. When I attempt to login as this user, I get an "Authentication failed. Please enter a valid username and password. The following message is in the error log:
<2009-07-13T14:58:06> Map Admin 128.223.67.19 tester
Error: Unauthorized access.
StackTrace:
- MgSiteServiceHandler.ProcessOperation line 83 file d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\site\SiteServiceHandler.cpp
- MgOpEnumerateServers.Execute line 96 file d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\site\OpEnumerateServers.cpp
- MgSecurityManager.Authenticate line 213 file d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\common\manager\SecurityManager.cpp Unauthorized access.
Any ideas what I'm doing wrong? I'm running the bundled Apache on Windows 2003 Server with a PHP development environment.
Cheers,
Dennis
View message @ http://n2.nabble.com/Non-Administrator-Users-Can%27t-Login-tp3257838p3308151.html
To unsubscribe from Non-Administrator Users Can't Login, click here.
View this message in context: RE: [mapguide-users] Non-Administrator Users Can't Login<http://n2.nabble.com/Non-Administrator-Users-Can%27t-Login-tp3257838p3334926.html>
Sent from the MapGuide Users mailing list archive<http://n2.nabble.com/MapGuide-Users-f1803227.html> at Nabble.com.
mapguide-users mailing list
mapguide-users at lists.osgeo.org<mailto:mapguide-users at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090729/361e6f8d/attachment.html
