[mapguide-users] Non-Administrator Users Can't Login
Dennis Soper dsoper at uoregon.edu
Wed Jul 29 13:48:27 EDT 2009
That's the issue.  I did set the users up using that URL and the users
cannot log in.  Administrator can log in.
Cheers,
Dennis
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kenneth
Skovhede, GEOGRAF A/S
Sent: Wednesday, July 29, 2009 12:41 AM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Non-Administrator Users Can't Login
You can manage users from the MapAdmin:
http://localhost/mapguide/mapadmin/login.php
These users can then log in to MapGuide.
You need to set their permissions to resources
with a tool like Maestro or Studio.
There are no execute permissions in MapGuide, only read and write.
The permission system is not really documented, and works the opposite
of what I expected.
Search the mailing lists for details.
Regards, Kenneth Skovhede, GEOGRAF A/S
Bloozitis skrev:
Hi Mauricio,
Could you please be so kind as to explain, in detail, what these
permissions are?  Currently, I have set up a test account and a user
account on the workstation with read and execute permissions.
Unfortunately, there is no mention in the documentation of what
permissions users need to access this.
Cheers,
Dennis
[mailto:ml-user+109705-477115064 at ...
<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=3334926&i=0> ]
Sent: Thursday, July 23, 2009 1:08 AM
To: Dennis Soper
You need to set the right permissions of the repository folders.
Bloozitis wrote:
I've created a test user, assigned it to a "mapauthors" group I created,
which assigns the user to the "Authors" role.  When I attempt to login
as this user, I get an "Authentication failed.  Please enter a valid
username and password.  The following message is in the error log:
<2009-07-13T14:58:06> Map Admin 128.223.67.19 tester
 Error: Unauthorized access.
 StackTrace:
  - MgSiteServiceHandler.ProcessOperation line 83 file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services
\site\SiteServiceHandler.cpp
  - MgOpEnumerateServers.Execute line 96 file
\site\OpEnumerateServers.cpp
  - MgSecurityManager.Authenticate line 213 file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\common\m
anager\SecurityManager.cpp Unauthorized access.
Any ideas what I'm doing wrong?  I'm running the bundled Apache on
Windows 2003 Server with a PHP development environment.
Cheers,
Dennis
View message @
http://n2.nabble.com/Non-Administrator-Users-Can%27t-Login-tp3257838p330
8151.html
To unsubscribe from Non-Administrator Users Can't Login, click here.
View this message in context: RE: [mapguide-users] Non-Administrator
Users Can't Login
<http://n2.nabble.com/Non-Administrator-Users-Can%27t-Login-tp3257838p33
34926.html>
Sent from the MapGuide Users mailing list archive
<http://n2.nabble.com/MapGuide-Users-f1803227.html>  at Nabble.com.
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090729/185fd257/attachment.html
