[mapguide-users] How to invoke URL?
Andrew DeMerchant andrew.demerchant at gemtec.ca
Mon Mar 16 10:00:22 EDT 2009
I think that you're all misunderstanding his question - he's asking
about InvokeURL, which works fine in Fusion....unless it's been broken
with the release of the last version. I've used InvokeURL quite a lot,
myself...Now, as for how to use it; Value should be $CurrentSelection,
yes. If you need to actually pull out data from a table and pass that to
a web page, that's a bit more involved, but not bad. Check Nabble for
info - look for PassData.php or posts by me.
Andrew
On 3/16/2009 10:39 AM, Ryan Northcott wrote:
> To repeat the above, the URL activated for Feature option will not
> work on Fusion layouts. Use a regular Layout.
> You would need to put in a value from your feature data into the URL
> activated expression.
> Build an expression like
> concat('/app/DataPullPage.aspx?date=', ToDate ( "AddedDate" ) )
> where
> app os the virtual directory or application directory on your web-server
> and DataPullPage.aspx (or .php) is the page you want data to show in
> the task panel.
> and AddedDate is a Date field in your feature attribute table of the
> data you are displaying.
> When you move you mouse over, there should be a yellow tool-tip saying
> press Cntrl+Click to open URL for this feature.
> If a user does that, the parameter is passed to your page with the
> value from your attribute table. You make the page then spit out
> whatever you need it to based on what you want your program to do with
> the feature.
> Pulling data out of a selected set is a bit labor intensive, and
> requires some good javaScript understanding. But Do-able.
> Good Luck
> On Mon, Mar 16, 2009 at 4:29 AM, achectl <achectl at gmail.com
> <mailto:achectl at gmail.com>> wrote:
>     Thanks.
>     Really?
>     What I tried?
>     I try to input the date for the key and $CurrentSelection for the
>     value.
>     The result is like that:
>     http://xx.xxx.xxx.xx/app?date=%24CurrentSelection
>     What is the meaning - %24CurrentSelection?
>     Any suggestion will be appreciate.
>     lolob wrote:
>     > I think you can't use invoke url in Fusion. I think it is for
>     Ajax only.
>     > achectl wrote:
>     >> Dear All,
>     >> I trying the invoke url feature. Fusion viewer is my testing
>     viewer. I
>     >> would like to pass the custom parameter to the application by
>     using url.
>     >> I make use of MapGuide Studio 2009. Inside the invoke url
>     command, i need
>     >> to input Key and Value of additional parameters. What is the
>     key and
>     >> value? Key is the attribute of the feature data? Value should be a
>     >> $CurrentSelection?
>     View this message in context:
>     http://n2.nabble.com/How-to-invoke-URL--tp2484189p2484665.html
>     Sent from the MapGuide Users mailing list archive at Nabble.com.
>     _______________________________________________
>     mapguide-users mailing list
>     mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/mapguide-users
	*Andrew DeMerchant*
*Computer Technologist*
ph.1-877-2GEMTEC x.163
fax 506-453-9470
/GEMTEC Limited <http://www.gemtec.ca>
/191 Doak Road
Fredericton, NB, Canada
E3C 2E6
Skipped content of type multipart/related
