[mapguide-users] How to invoke URL?
achectl achectl at gmail.com
Mon Mar 16 10:46:33 EDT 2009
Hi Andrew
Thanks for your information.
I tried to fix the invokeURL.java
(http://trac.osgeo.org/mapguide/ticket/832), but seems it doesn't work! :-((
I would like to confirm that "Key" should be the attribute of the feature
data? If the column attribute is called "Data", where I should to input?
Now it only show %24CurrentSelection for the value.
Regards,
Achectl
Andrew DeMerchant wrote:
> I think that you're all misunderstanding his question - he's asking
> about InvokeURL, which works fine in Fusion....unless it's been broken
> with the release of the last version. I've used InvokeURL quite a lot,
> myself...Now, as for how to use it; Value should be $CurrentSelection,
> yes. If you need to actually pull out data from a table and pass that to
> a web page, that's a bit more involved, but not bad. Check Nabble for
> info - look for PassData.php or posts by me.
> Andrew
> On 3/16/2009 10:39 AM, Ryan Northcott wrote:
>> To repeat the above, the URL activated for Feature option will not
>> work on Fusion layouts. Use a regular Layout.
>> You would need to put in a value from your feature data into the URL
>> activated expression.
>> Build an expression like
>> concat('/app/DataPullPage.aspx?date=', ToDate ( "AddedDate" ) )
>> where
>> app os the virtual directory or application directory on your web-server
>> and DataPullPage.aspx (or .php) is the page you want data to show in
>> the task panel.
>> and AddedDate is a Date field in your feature attribute table of the
>> data you are displaying.
>> When you move you mouse over, there should be a yellow tool-tip saying
>> press Cntrl+Click to open URL for this feature.
>> If a user does that, the parameter is passed to your page with the
>> value from your attribute table. You make the page then spit out
>> whatever you need it to based on what you want your program to do with
>> the feature.
>> Pulling data out of a selected set is a bit labor intensive, and
>> requires some good javaScript understanding. But Do-able.
>> Good Luck
>> On Mon, Mar 16, 2009 at 4:29 AM, achectl <achectl at gmail.com
>> <mailto:achectl at gmail.com>> wrote:
>>     Thanks.
>>     Really?
>>     What I tried?
>>     I try to input the date for the key and $CurrentSelection for the
>>     value.
>>     The result is like that:
>>     http://xx.xxx.xxx.xx/app?date=%24CurrentSelection
>>     What is the meaning - %24CurrentSelection?
>>     Any suggestion will be appreciate.
>>     lolob wrote:
>>     > I think you can't use invoke url in Fusion. I think it is for
>>     Ajax only.
>>     > achectl wrote:
>>     >> Dear All,
>>     >> I trying the invoke url feature. Fusion viewer is my testing
>>     viewer. I
>>     >> would like to pass the custom parameter to the application by
>>     using url.
>>     >> I make use of MapGuide Studio 2009. Inside the invoke url
>>     command, i need
>>     >> to input Key and Value of additional parameters. What is the
>>     key and
>>     >> value? Key is the attribute of the feature data? Value should be a
>>     >> $CurrentSelection?
>>     View this message in context:
>>     http://n2.nabble.com/How-to-invoke-URL--tp2484189p2484665.html
>>     Sent from the MapGuide Users mailing list archive at Nabble.com.
>>     _______________________________________________
>>     mapguide-users mailing list
>>     mapguide-users at lists.osgeo.org
>> <mailto:mapguide-users at lists.osgeo.org>
>>     http://lists.osgeo.org/mailman/listinfo/mapguide-users
> 	*Andrew DeMerchant*
> *Computer Technologist*
> ph.1-877-2GEMTEC x.163
> fax 506-453-9470
> /GEMTEC Limited <http://www.gemtec.ca>
> /191 Doak Road
> Fredericton, NB, Canada
> E3C 2E6
View this message in context: http://n2.nabble.com/How-to-invoke-URL--tp2484189p2486461.html
