[mapguide-users] Server 2008 IIS7 ASP.Net 2.0 Error when editing SDF
Jamo adam.jamison at portbris.com.au
Mon May 4 23:06:40 EDT 2009
Cheers Jason,
I've updated the bin directory now :),
always the little things....
Cheers !
Any Idea why the propertyCtrl would be reading a .php version ? When initial
loading of the page is done I swap the HTML of the PropertyCtrl Iframe, this
has always been ../mapviewerajax/propertyctrl.aspx but I notice it is
../mapviewerajax/propertyctrl.php now? I have amended the code so it works,
however it does not make sense ....
../mapguide2010/mapviewerajax/propertyctrl.php does not exist.... however
the code evaluates it and accepts it ?
IIS shows /mapguide2010/mapviewerajax with physical path of
D:\mapguide\web\www\mapviewernet which only contains asp.net code ..... no
php?
  function SetPropertyPage()
  var mapFrame = parent.parent.mapFrame;
  var propertyCtrl = mapFrame.document.getElementById("PropertyCtrl");
  alert(propertyCtrl.src);
  if(propertyCtrl.src == "../mapguide2010/mapviewerajax/propertyctrl.php" |
propertyCtrl.src ==
"/mapguide2010/mapviewerajax/propertyctrl.php?LOCALE=en")
      propertyCtrl.src = "../portmisc/Edit/Properties/PropTemplLoader.aspx";
      else
      propertyCtrl.src = "../mapviewerajax/propertyctrl.aspx";
Jason Birch wrote:
> That's nice of them :)
> Did you update the files in your web app's bin directory with those from
> the MG 2010 release?
> Jason
View this message in context: http://n2.nabble.com/Server-2008-IIS7-ASP.Net-2.0-Error-when-editing-SDF-tp2790767p2790833.html
