[mapguide-users] Server 2008 IIS7 ASP.Net 2.0 Error when editing SDF
Jason Birch Jason.Birch at nanaimo.ca
Mon May 4 23:53:15 EDT 2009
No, that's odd and it doesn't make a lot of sense.  The template loading code in mapframe.aspx appears to be substituting the correct value:
http://trac.osgeo.org/mapguide/browser/trunk/MgDev/Web/src/mapviewernet/mapframe.aspx#L187
Did you ever have mapviewerajax pointing at the PHP version on that machine?  I wonder if it's possible that you have a stale version of one of the sub-frames loaded in your browser cache or an inline proxy.
Try flushing your browser cache, and then watching what happens during page load using something like Fiddler2...
Jason
________________________________________
Sent: Monday, May 04, 2009 8:06 PM
To: mapguide-users at lists.osgeo.org
Subject: RE: [mapguide-users] Server 2008 IIS7 ASP.Net 2.0 Error when   editing SDF
Any Idea why the propertyCtrl would be reading a .php version ? When initial
loading of the page is done I swap the HTML of the PropertyCtrl Iframe, this
has always been ../mapviewerajax/propertyctrl.aspx but I notice it is
../mapviewerajax/propertyctrl.php now? I have amended the code so it works,
however it does not make sense ....
../mapguide2010/mapviewerajax/propertyctrl.php does not exist.... however
the code evaluates it and accepts it ?
