[mapguide-users] King.Oracle IN statement fails with a parenthesiserror WAS: Filter Error
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Tue May 5 05:38:51 EDT 2009
One of my co-workers has seen the same issue,
so it's likely a bug in the provider.
Please create a bug report for the problem on the FDO site.
A dirty workaround is to use:
LINK_ID=170 OR LINK_ID=143 OR LINK_ID=150
Regards, Kenneth Skovhede, GEOGRAF A/S
padmini godavarthi skrev:
> Hi,
> iam using mapguide opensource 2.0 (with .net 2.0 +IIS 5.1)
> Now my problem is "In" operator is not working in Setfilter option
> My code is as follows..................................
>      Dim queryoptions As MgFeatureQueryOptions = New MgFeatureQueryOptions()
>         queryoptions.AddFeatureProperty("LINK_ID")
>         queryoptions.SetFilter("LINK_ID IN (170,143,150)")
>         Dim increment1 As Double = IIf((5 > 1), 1.0 / (5 - 1), 1.0)
>         Dim str As String = layer.GetFeatureClassName()
>         Dim dataReader1 As MgFeatureReader =
> featureService.SelectFeatures(resId, layer.GetFeatureClassName(),
> queryoptions)
>         While dataReader1.ReadNext()
>             value = GetFeaturePropertyValue(dataReader1, "LINK_ID")
>             filterText = """ + "LINK_ID" + "" = "
>             filterText = filterText + value
>             areaRuleXML = String.Format(areaRuleTemplate, "LINK_ID" + ":" +
> value, filterText, InterpolateColor(portion, "00FF00", "00FF00", 0),
> InterpolateColor(portion, "00FF00", "00FF00", 0))
>             areaDoc = New XmlDocument()
>             areaDoc.LoadXml(areaRuleXML)
>             areaNode = doc.ImportNode(areaDoc.DocumentElement, True)
>             areaTypeStyle.AppendChild(areaNode)
>             portion = portion + increment1
>         End While
>         dataReader1.Close()
> It gives me the following error
> queryoptions)
> as
> An exception occurred in FDO component.
> ORA-00907: missing right parenthesis
> In this case Link ID  is  integer values not a string
> value......................................
> can u plz tell me the solution
> i have also tried as
>    queryoptions.SetFilter("LINK_ID IN ({170},{143},{150})") but it gave me
> the error as "not a valid filter"
> Can anyone plz tell me the solution???????????????????/
> plzzzzzzzzzzzzzzzz
> Regards,
> Padmini.
