[mapguide-users] Filter Error
Haris Kurtagic haris at sl-king.com
Tue May 5 10:26:06 EDT 2009
Which version of provider are using ?
I remember that bug but it was solved sometime ago.
I just tried with Fdo2Fdo and set Filter with IN and it works fine.
Haris
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of padmini
godavarthi
Sent: Tuesday, May 05, 2009 10:44 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Filter Error
iam using mapguide opensource 2.0 (with .net 2.0 +IIS 5.1)
Now my problem is "In" operator is not working in Setfilter option
My code is as follows..................................
     Dim queryoptions As MgFeatureQueryOptions = New
MgFeatureQueryOptions()
        queryoptions.AddFeatureProperty("LINK_ID")
        queryoptions.SetFilter("LINK_ID IN (170,143,150)")
        Dim increment1 As Double = IIf((5 > 1), 1.0 / (5 - 1), 1.0)
        Dim str As String = layer.GetFeatureClassName()
        Dim dataReader1 As MgFeatureReader =
featureService.SelectFeatures(resId, layer.GetFeatureClassName(),
queryoptions)
        While dataReader1.ReadNext()
            value = GetFeaturePropertyValue(dataReader1, "LINK_ID")
            filterText = """ + "LINK_ID" + "" = "
            filterText = filterText + value
            areaRuleXML = String.Format(areaRuleTemplate, "LINK_ID" +
value, filterText, InterpolateColor(portion, "00FF00", "00FF00", 0),
InterpolateColor(portion, "00FF00", "00FF00", 0))
            areaDoc = New XmlDocument()
            areaDoc.LoadXml(areaRuleXML)
            areaNode = doc.ImportNode(areaDoc.DocumentElement, True)
            areaTypeStyle.AppendChild(areaNode)
            portion = portion + increment1
        End While
        dataReader1.Close()
It gives me the following error
queryoptions)
as
An exception occurred in FDO component.
ORA-00907: missing right parenthesis
In this case Link ID  is  integer values not a string
value......................................
can u plz tell me the solution
i have also tried as
   queryoptions.SetFilter("LINK_ID IN ({170},{143},{150})") but it gave
me
the error as "not a valid filter"
Can anyone plz tell me the solution???????????????????/
plzzzzzzzzzzzzzzzz
Regards,
Padmini.
View this message in context:
http://n2.nabble.com/Filter-Error-tp2791694p2791694.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
