[mapguide-users] Filter Error
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Tue May 5 10:49:34 EDT 2009
I was using the one that was included with FDO 3.3.2,
I will try with a newer version at some point.
Regards, Kenneth Skovhede, GEOGRAF A/S
Haris Kurtagic skrev:
> Which version of provider are using ?
> I remember that bug but it was solved sometime ago.
> I just tried with Fdo2Fdo and set Filter with IN and it works fine.
> Haris
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of padmini
> godavarthi
> Sent: Tuesday, May 05, 2009 10:44 AM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] Filter Error
> Hi,
> iam using mapguide opensource 2.0 (with .net 2.0 +IIS 5.1)
> Now my problem is "In" operator is not working in Setfilter option
> My code is as follows..................................
>      Dim queryoptions As MgFeatureQueryOptions = New
> MgFeatureQueryOptions()
>         queryoptions.AddFeatureProperty("LINK_ID")
>         queryoptions.SetFilter("LINK_ID IN (170,143,150)")
>         Dim increment1 As Double = IIf((5 > 1), 1.0 / (5 - 1), 1.0)
>         Dim str As String = layer.GetFeatureClassName()
>         Dim dataReader1 As MgFeatureReader =
> featureService.SelectFeatures(resId, layer.GetFeatureClassName(),
> queryoptions)
>         While dataReader1.ReadNext()
>             value = GetFeaturePropertyValue(dataReader1, "LINK_ID")
>             filterText = """ + "LINK_ID" + "" = "
>             filterText = filterText + value
>             areaRuleXML = String.Format(areaRuleTemplate, "LINK_ID" +
> value, filterText, InterpolateColor(portion, "00FF00", "00FF00", 0),
> InterpolateColor(portion, "00FF00", "00FF00", 0))
>             areaDoc = New XmlDocument()
>             areaDoc.LoadXml(areaRuleXML)
>             areaNode = doc.ImportNode(areaDoc.DocumentElement, True)
>             areaTypeStyle.AppendChild(areaNode)
>             portion = portion + increment1
>         End While
>         dataReader1.Close()
> It gives me the following error
> queryoptions)
> as
> An exception occurred in FDO component.
> ORA-00907: missing right parenthesis
> In this case Link ID  is  integer values not a string
> value......................................
> can u plz tell me the solution
> i have also tried as
>    queryoptions.SetFilter("LINK_ID IN ({170},{143},{150})") but it gave
> me
> the error as "not a valid filter"
> Can anyone plz tell me the solution???????????????????/
> plzzzzzzzzzzzzzzzz
> Regards,
> Padmini.
