[mapguide-users] Performance Problem using DWF
Luis Paolini l_paolini at uol.com.br
Fri May 15 09:27:06 EDT 2009
Martin,
                Thank you for the tips. I'll take a look in the help system.
Luis
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Martin Morrison
Sent: Friday, May 15, 2009 10:17 AM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] Performance Problem using DWF
In Map 3D you need to make sure the dwg is in good shape before you export
to either MapGuide or DWF.  Sometimes getting back to the basics are the
only way to fix issues.
The way to run audit is to type "audit" on the command line in Map 3D and
then decide whether or not to let it fix the errors.  Typically I run audit
once without fixing just to see what I am up against and then run it a
second time and let it fix the errors.  Sometimes you have to audit a couple
times in a row to get the dwg clean.  If it doesn't clean up you may have
bigger issues than audit can take care of and you need to resolve those.
The most important keyboard button is F1, it brings up help.  There is
detailed information in help on all of the processes that I listed below.
Martin
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Luis Paolini
Sent: Friday, May 15, 2009 9:01 AM
To: 'MapGuide Users Mail List'
Martin,
                I did not audited the dwg and to be honest, I don't know how
to do it.
                These auditing operations should be done using Mapguide?
Luis
Sent: Friday, May 15, 2009 9:49 AM
Something is wrong with the larger dwg.  Have you audited the dwg?  Run
MapCleanup?  Purge?  Cleaned up excessive scales?
Martin
Sent: Friday, May 15, 2009 8:32 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Performance Problem using DWF
    I'm a new Mapguide user and need some help to fix a performance problem
publishing DWF data.
    Using Autodesk Map 3D I published a DWG to Mapguide. The DWG file has
10Mbytes and the processo took 7 hours. I think that it is too much time and
something must be wrong but let's move on.
    After that, using Autodesk Studio, I tried to preview the layer created
(DWF) and the preview windows keeps retrieving data forever and shows
nothing. At the other side, Mapguide Server Processe allocate a lot of my
server resources (memory and CPU) for hours and do nothing.
     I also configured the layer to accept WMS requests, but when I send a
GetMap request the same problem happens. No map is returned and the server
resources are increased.
     I did the same process with a smaller file (1 Mbyte) and it worked
pretty fine. This small file has the same layers that the big one, but with
less features.
     Have you guys some ideas?
Regards,
Luis
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090515/b949b4e4/attachment.html
