[mapguide-users] Performance Problem using DWF
James H. Murphy jhm at alacad.com
Fri May 15 10:31:03 EDT 2009
Luis,
Along with what Martin stated also use the purge command (in Map3D) and
it might be better to use the -purge command at the command line
(prefixed with hyphen) and tell it to purge all to include the App IDs.
The other suggection is to convert the DWG objects to SDF then load
those into the dwg with data connect (delete the dwg objects) and style
them there or in Studio after you publish to Map Guide.
James Murphy
Geospatial Solutions Specialist
ALACAD
(205) 444-3100
www.alacad.com
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Luis
Paolini
Sent: May 15, 2009 8:27 AM
To: 'MapGuide Users Mail List'
Subject: RE: [mapguide-users] Performance Problem using DWF
Martin,
                Thank you for the tips. I'll take a look in the help
system.
Luis
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Martin
Morrison
Sent: Friday, May 15, 2009 10:17 AM
To: MapGuide Users Mail List
In Map 3D you need to make sure the dwg is in good shape before you
export to either MapGuide or DWF.  Sometimes getting back to the basics
are the only way to fix issues.
The way to run audit is to type "audit" on the command line in Map 3D
and then decide whether or not to let it fix the errors.  Typically I
run audit once without fixing just to see what I am up against and then
run it a second time and let it fix the errors.  Sometimes you have to
audit a couple times in a row to get the dwg clean.  If it doesn't clean
up you may have bigger issues than audit can take care of and you need
to resolve those.
The most important keyboard button is F1, it brings up help.  There is
detailed information in help on all of the processes that I listed
below.
Martin
Paolini
Sent: Friday, May 15, 2009 9:01 AM
Martin,
                I did not audited the dwg and to be honest, I don't know
how to do it.
                These auditing operations should be done using Mapguide?
Luis
Morrison
Sent: Friday, May 15, 2009 9:49 AM
Something is wrong with the larger dwg.  Have you audited the dwg?  Run
MapCleanup?  Purge?  Cleaned up excessive scales?
Martin
Paolini
Sent: Friday, May 15, 2009 8:32 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Performance Problem using DWF
    I'm a new Mapguide user and need some help to fix a performance
problem publishing DWF data.
    Using Autodesk Map 3D I published a DWG to Mapguide. The DWG file
has 10Mbytes and the processo took 7 hours. I think that it is too much
time and something must be wrong but let's move on.
    After that, using Autodesk Studio, I tried to preview the layer
created (DWF) and the preview windows keeps retrieving data forever and
shows nothing. At the other side, Mapguide Server Processe allocate a
lot of my server resources (memory and CPU) for hours and do nothing.
     I also configured the layer to accept WMS requests, but when I send
a GetMap request the same problem happens. No map is returned and the
server resources are increased.
     I did the same process with a smaller file (1 Mbyte) and it worked
pretty fine. This small file has the same layers that the big one, but
with less features.
     Have you guys some ideas?
Regards,
Luis
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090515/c9947cce/attachment.html
