[mapguide-users] GetDefaultGeometryPropertyName returning nothing in latest 2.1 install
Jason Birch Jason.Birch at nanaimo.ca
Thu May 21 11:11:57 EDT 2009
Hi Colin,
Yes, definitely enter a ticket for this, preferably with a (truncated) SHP file that exhibits this behaviour.  If the devs can't duplicate it, they can't fix it. :)
Which version of the installer was the last one you remember this working correctly with?
Jason
-----Original Message-----
Sent: Thursday, May 21, 2009 1:49 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] GetDefaultGeometryPropertyName returning nothing in latest 2.1 install
I just installed the lastest 2.1 installer (0.7). Now when i do
GetDefaultGeometryPropertyName on my MgClassDefinition for my shp file data
sources I sometimes get nothing returned whereas in previous installs it
reported the correct geometry. This can be seen in Maestro as well where the
geometry field is blank for these data sources. A blank return used to
happen on for Rasters.
Has anyone seen this before or should I raise a ticket perhaps? It only
seems to happen to some of my shp files but as i say these all worked in 2.0
and 2.1 pre 0.7 install.
