[mapguide-users] GetDefaultGeometryPropertyName returning nothing in latest 2.1 install
cagray colin.gray at 1spatial.com
Fri May 22 05:45:01 EDT 2009
Assuming it was the new version which has caused this (maybe I have made a
leap!), I just installed using the 0.7 version and the 0.6 installer did not
show this behaviour. I can take 0.7 off, put 0.6 on just to make sure it is
indeed the install that has caused this and then raise a ticket.
Jason Birch wrote:
> Hi Colin,
> Yes, definitely enter a ticket for this, preferably with a (truncated) SHP
> file that exhibits this behaviour.  If the devs can't duplicate it, they
> can't fix it. :)
> Which version of the installer was the last one you remember this working
> correctly with?
> Jason
> -----Original Message-----
> From: cagray
> Sent: Thursday, May 21, 2009 1:49 AM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] GetDefaultGeometryPropertyName returning nothing
> I just installed the lastest 2.1 installer (0.7). Now when i do
> GetDefaultGeometryPropertyName on my MgClassDefinition for my shp file
> data
> sources I sometimes get nothing returned whereas in previous installs it
> reported the correct geometry. This can be seen in Maestro as well where
> the
> geometry field is blank for these data sources. A blank return used to
> happen on for Rasters.
> Has anyone seen this before or should I raise a ticket perhaps? It only
> seems to happen to some of my shp files but as i say these all worked in
> 2.0
> and 2.1 pre 0.7 install.
> mapguide-users mailing list
View this message in context: http://n2.nabble.com/GetDefaultGeometryPropertyName-returning-nothing-in-latest-2.1-install-tp2950901p2956495.html
