[mapguide-users] Creating and adding layers
oshan icycool at inbox.com
Wed Nov 4 22:24:19 EST 2009
By the way I'm using mapguide os 2.0 with jsp extension. does this come with
the GDAL plugin to handle all the raster data? I checked in my bin folder
and there is no gdalplugins folder! But inside FDO I have a file called
gdal14.dll. If this is not enough where do I get this full plugin from and
which version. The version of the gdal14.dll is 1.4.3.0
cheers
oshan wrote:
> Hi Kenneth
> Thanks for you reply. I'm basically trying to get a map displayed in the
> ajax viewer and the map I'm planning to use is a raster image.
> I tried doing it using map guide maestro but I couldn't get the image
> displayed. I tnk its something to do with the coordinate system may be its
> way off the screen.
> I was looking at GDAL and found this link. It kind shows how to add
> coordinate to raster image. I'll try that and see if it works.
> http://trac.osgeo.org/gdal/wiki/UserDocs/RasterProcTutorial
> By the way do you mean data files like .shp? what is a good free client I
> used to create such data?
> Thanks
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> There is a short (incomplete) guide here that explains the procedure
>> from a users viewpoint:
>> http://trac.osgeo.org/mapguide/wiki/maestro/UserGuide
>> If you have MapGuide Enterprise, you can get Studio for free, which has
>> a manual in the "Help" menu.
>> If you need to create data as well, you need a GIS client application,
>> such as Autocad Map, ArcGIS or MapInfo.
>> (There are free clients avalible as well)
>> Your question is a bit vague, so if this is an answer to another
>> question, can you explain your current setup?
>> Regards, Kenneth Skovhede, GEOGRAF A/S
>> oshan skrev:
>>> Hi
>>> I want to know how to create layers?
>>> Say that you have a map and you want to create layers for political
>>> divisions. How would you go about doing this?
>>> I ask this before but I didn't get any answer. My apologies if its a
>>> stupic
>>> question! Since I don't really have any good vectored based maps, is it
>>> possible to use a jpeg as a base image? How do I achieve this?
>>> I appreciate any help
>>> Thanks
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://n2.nabble.com/Creating-and-adding-layers-tp3941863p3949989.html
