[mapguide-users] Creating and adding layers
Zac Spitzer zac.spitzer at gmail.com
Thu Nov 5 18:33:41 EST 2009
don't even bother with GDAL unless your using a 2.1 build,
it's really broken
2.1 also does raster reprojection and is more stable
z
On Thu, Nov 5, 2009 at 7:07 PM, Kenneth Skovhede, GEOGRAF A/S
<ks at geograf.dk> wrote:
> Rasters are notoriously difficult to get to work.
> First of, you need to run the server from the console with the CPL_DEBUG=on:
> http://trac.osgeo.org/fdo/wiki/FdoGdalNotes
> (See at the bottom of the page).
> And you have to create the gdalplugin folder yourself, so you get the file
> layout
> as described on FdoGdalNotes page.
> Your MapDefinition coordinate system and raster coordinate system MUST match
> 100%.
> Also look in the error log file:
> C:\Program Files\MapGuideOpenSource2.0\Server\Logs\Error.log
> For a free vector editor, try Kosmo GIS:
> http://www.opengis.es/
> Good luck!
> Regards, Kenneth Skovhede, GEOGRAF A/S
> oshan skrev:
> By the way I'm using mapguide os 2.0 with jsp extension. does this come with
> the GDAL plugin to handle all the raster data? I checked in my bin folder
> and there is no gdalplugins folder! But inside FDO I have a file called
> gdal14.dll. If this is not enough where do I get this full plugin from and
> which version. The version of the gdal14.dll is 1.4.3.0
> cheers
> oshan wrote:
> Hi Kenneth
> Thanks for you reply. I'm basically trying to get a map displayed in the
> ajax viewer and the map I'm planning to use is a raster image.
> I tried doing it using map guide maestro but I couldn't get the image
> displayed. I tnk its something to do with the coordinate system may be its
> way off the screen.
> I was looking at GDAL and found this link. It kind shows how to add
> coordinate to raster image. I'll try that and see if it works.
> http://trac.osgeo.org/gdal/wiki/UserDocs/RasterProcTutorial
> By the way do you mean data files like .shp? what is a good free client I
> used to create such data?
> Thanks
> Kenneth Skovhede, GEOGRAF A/S wrote:
> There is a short (incomplete) guide here that explains the procedure
> from a users viewpoint:
> http://trac.osgeo.org/mapguide/wiki/maestro/UserGuide
> If you have MapGuide Enterprise, you can get Studio for free, which has
> a manual in the "Help" menu.
> If you need to create data as well, you need a GIS client application,
> such as Autocad Map, ArcGIS or MapInfo.
> (There are free clients avalible as well)
> Your question is a bit vague, so if this is an answer to another
> question, can you explain your current setup?
> oshan skrev:
> Hi
> I want to know how to create layers?
> Say that you have a map and you want to create layers for political
> divisions. How would you go about doing this?
> I ask this before but I didn't get any answer. My apologies if its a
> stupic
> question! Since I don't really have any good vectored based maps, is it
> possible to use a jpeg as a base image? How do I achieve this?
> I appreciate any help
> Thanks
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
