[mapguide-users] Inser feature problem
mighty_duck msiljegovic at gmail.com
Mon Nov 9 04:09:22 EST 2009
Autodesk FDO provider for Oracle
Dejan Gregor wrote:
> mighty_duck,
> you have several Oracle FDO providers and versions (check
> http://fdo.osgeo.org/OSProviderOverviews.html). Which one (name, version)
> are you using?
> Dejan
> On Mon, Nov 9, 2009 at 10:05, mighty_duck <msiljegovic at gmail.com> wrote:
>> FDO
>> zspitzer wrote:
>> > which provider are you using?
>> > On Mon, Nov 9, 2009 at 8:01 PM, mighty_duck <msiljegovic at gmail.com>
>> wrote:
>> >> I dont think it is Oracle error, it inserts everything correcly to
>> >> database,
>> >> problem start when FeatureService wants to return "information" that
>> >> feature
>> >> is succesufully inserted into the database.
>> >> Wouldn't it be maybe FDO problem?!
>> >> thanks
>> >> Dejan Gregor wrote:
>> >>> What is the ORA error/exception number?
>> >>> Dejan
>> >>> On Mon, Nov 9, 2009 at 09:42, mighty_duck <msiljegovic at gmail.com>
>> wrote:
>> >>>> Hi,
>> >>>> I created table in Oracle with two columns: ID(primary key) and
>> >>>> Geometry(SDO_GEOMETRY). I also done all stuffs with metadata and
>> >>>> spatial
>> >>>> index.....
>> >>>> Problem is when I want to insert feature into the table...
>> >>>> featureService.UpdateFeatures(resourceIdentifier, commandCollection,
>> >>>> false);. This command correctly inserts new feature into the table,
>> but
>> >>>> throws also exception depending if I specify ID directly (Feature
>> >>>> service
>> >>>> exception - error occurred while insert operation, no ID to
>> retrieve),
>> >>>> or
>> >>>> I
>> >>>> let Oracle autogenerates the new ID(An unclassified exception
>> >>>> occurred).
>> >>>> So in both cases feature is inserted into the table, but everytime I
>> >>>> get
>> >>>> exception, and I cant realize what cause this problem!!!
>> >>>> thanks in advance
>> >>>> View this message in context:
>> >>>> http://n2.nabble.com/Inser-feature-problem-tp3971827p3971827.html
>> >>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> >>>> _______________________________________________
>> >>>> mapguide-users mailing list
>> >>>> mapguide-users at lists.osgeo.org
>> >>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> >> http://n2.nabble.com/Inser-feature-problem-tp3971827p3971881.html
>> > Zac Spitzer
>> > Solution Architect / Director
>> > Ennoble Consultancy Australia
>> > http://www.ennoble.com.au
>> > http://zacster.blogspot.com
>> > +61 405 847 168
>> http://n2.nabble.com/Inser-feature-problem-tp3971827p3971901.html
View this message in context: http://n2.nabble.com/Inser-feature-problem-tp3971827p3971926.html
