[mapguide-users] Inser feature problem
Zac Spitzer zac.spitzer at gmail.com
Mon Nov 9 04:11:29 EST 2009
I would try the posting on the mge groups?
On Mon, Nov 9, 2009 at 8:09 PM, mighty_duck <msiljegovic at gmail.com> wrote:
> Autodesk FDO provider for Oracle
> Dejan Gregor wrote:
>> mighty_duck,
>> you have several Oracle FDO providers and versions (check
>> http://fdo.osgeo.org/OSProviderOverviews.html). Which one (name, version)
>> are you using?
>> Dejan
>> On Mon, Nov 9, 2009 at 10:05, mighty_duck <msiljegovic at gmail.com> wrote:
>>> FDO
>>> zspitzer wrote:
>>> > which provider are you using?
>>> > On Mon, Nov 9, 2009 at 8:01 PM, mighty_duck <msiljegovic at gmail.com>
>>> wrote:
>>> >> I dont think it is Oracle error, it inserts everything correcly to
>>> >> database,
>>> >> problem start when FeatureService wants to return "information" that
>>> >> feature
>>> >> is succesufully inserted into the database.
>>> >> Wouldn't it be maybe FDO problem?!
>>> >> thanks
>>> >> Dejan Gregor wrote:
>>> >>> What is the ORA error/exception number?
>>> >>> Dejan
>>> >>> On Mon, Nov 9, 2009 at 09:42, mighty_duck <msiljegovic at gmail.com>
>>> wrote:
>>> >>>> Hi,
>>> >>>> I created table in Oracle with two columns: ID(primary key) and
>>> >>>> Geometry(SDO_GEOMETRY). I also done all stuffs with metadata and
>>> >>>> spatial
>>> >>>> index.....
>>> >>>> Problem is when I want to insert feature into the table...
>>> >>>> featureService.UpdateFeatures(resourceIdentifier, commandCollection,
>>> >>>> false);. This command correctly inserts new feature into the table,
>>> but
>>> >>>> throws also exception depending if I specify ID directly (Feature
>>> >>>> service
>>> >>>> exception - error occurred while insert operation, no ID to
>>> retrieve),
>>> >>>> or
>>> >>>> I
>>> >>>> let Oracle autogenerates the new ID(An unclassified exception
>>> >>>> occurred).
>>> >>>> So in both cases feature is inserted into the table, but everytime I
>>> >>>> get
>>> >>>> exception, and I cant realize what cause this problem!!!
>>> >>>> thanks in advance
>>> >>>> View this message in context:
>>> >>>> http://n2.nabble.com/Inser-feature-problem-tp3971827p3971827.html
>>> >>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>> >>>> _______________________________________________
>>> >>>> mapguide-users mailing list
>>> >>>> mapguide-users at lists.osgeo.org
>>> >>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>> >> http://n2.nabble.com/Inser-feature-problem-tp3971827p3971881.html
>>> > Zac Spitzer
>>> > Solution Architect / Director
>>> > Ennoble Consultancy Australia
>>> > http://www.ennoble.com.au
>>> > http://zacster.blogspot.com
>>> > +61 405 847 168
>>> http://n2.nabble.com/Inser-feature-problem-tp3971827p3971901.html
> View this message in context: http://n2.nabble.com/Inser-feature-problem-tp3971827p3971926.html
Zac Spitzer
+61 405 847 168
