[mapguide-users] GETMAPIMAGE vs GETDYNAMICMAPOVERLAYIMAGE and out
	of memory issue
    cagray
    colin.gray at 1spatial.com
    Tue Nov 17 03:44:52 EST 2009
I am trying to generate images by mimicing the calls done in the AJAX map
viewer. I notice that in the ajaxmappane.templ it only ever uses
GETDYNAMICMAPOVERLAYIMAGE. I was wondering what the difference was from just
using GETMAPIMAGE?
Also if I try and do images over 1024 by 1024 I always get an out of memory
error returned. Is there any way around this such as a setting in the
server.config? Sometimes I even get an out of memory for 1024 by 1024
depending on the map and have to reduce it do 512 by 512. Any thoughts?
Thanks
Colin
View this message in context: http://n2.nabble.com/GETMAPIMAGE-vs-GETDYNAMICMAPOVERLAYIMAGE-and-out-of-memory-issue-tp4017282p4017282.html
