[mapguide-users] Re: Query external files
luisbap luisbap at hotmail.com
Wed Feb 10 10:24:31 EST 2010
Hello again Sudip,
the problem with the propagation of properties is solved. The code was
looking for properties based on legend name when naem and legend name were
different. Like this, it was not possible to find any properties because the
name didn't match.
Now, I have different 2 problems related only with the properties in the
Query functionality
1) When I select a layer, the properties in the dropdown list, appear with
the Property Name instead of the "Name to display". In the properties pane
that "name to display" is correct.
How can I get the "Name to display" and use it in the dropdown list?
2) I'm using external SDF files connecting to an Oracle database. For each
layer I have 2 different schemas. As example:
Schema1:SDF1 (connecting to SDF)
Schema1:SDFextended (the one that is in use, connecting SDF to Oracle)
If I query based on any property that come from SDF, it works fine.
If I query based on any property that come from Oracle DB I get the
following error:
    "Error: An exception occurred in FDO component. Failed to execute
query."
Can anyone help me on these subjects?
thanks in advance
View this message in context: http://n2.nabble.com/Query-external-files-tp4515007p4548539.html
