[mapguide-users] IIS 7.0 Forbidden when opening /mapguide/ (from browser and Maestro)
BojanFranc at FER bojan.franc at fer.hr
Tue Feb 16 04:30:54 EST 2010
I was running MGOS with Apache so far, now want to use it with IIS.
A got a IIS configuration error somewhere, I think...
I can open MapAdmin and MapAgent with no problems.
http://server.ip/mapguide/mapadmin
... redirects me to login.php and works OK...
http://server.ip/mapguide/mapagent
... works OK
But when I try to open http://server.ip/mapguide/ from browser or connect
from Maestro,
I get ...
403 - Forbidden: Access is denied.
You do not have permission to view this directory or page using the
credentials that you supplied.
I am using IIS 7.0 on a Win2008 R2 server. It's a clean install, I only
changed some options in IIS to get PHP working.
What am I missing?
Regards,
 B. Franc
View this message in context: http://n2.nabble.com/IIS-7-0-Forbidden-when-opening-mapguide-from-browser-and-Maestro-tp4579338p4579338.html
