[mapguide-users] IIS 7.0 Forbidden when opening /mapguide/ (from browser and Maestro)
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Tue Feb 16 06:40:58 EST 2010
Try entering the full url into Maestro:
http://server.ip/mapguide/mapagent/mapagent.fcgi
If you use the shorter version, Maestro will attempt to use that first,
then try to append "mapagent/mapagent.fcgi",
but if the second attempt also fails, you get the error from the short one.
Regards, Kenneth Skovhede, GEOGRAF A/S
On 16-02-2010 10:30, BojanFranc at FER wrote:
> Hi,
> I was running MGOS with Apache so far, now want to use it with IIS.
> A got a IIS configuration error somewhere, I think...
> I can open MapAdmin and MapAgent with no problems.
> http://server.ip/mapguide/mapadmin
> ... redirects me to login.php and works OK...
> ... works OK
> But when I try to open http://server.ip/mapguide/ from browser or connect
> from Maestro,
> I get ...
> 403 - Forbidden: Access is denied.
> You do not have permission to view this directory or page using the
> credentials that you supplied.
> I am using IIS 7.0 on a Win2008 R2 server. It's a clean install, I only
> changed some options in IIS to get PHP working.
> What am I missing?
> Regards,
>   B. Franc
