[mapguide-users] RE: GeoREST 1.0 Released!
BradM brad.mason at dfo-mpo.gc.ca
Thu Feb 18 16:29:52 EST 2010
Haris,  could you please check to see if your basic sample is working at:
http://www.sl-king.com/georestsamples <https://webmail.pac.dfo-mpo.gc.ca/exchweb/bin/redir.asp?URL=http://www.sl-king.com/georestsamples/example1/rview.html> / <https://webmail.pac.dfo-mpo.gc.ca/exchweb/bin/redir.asp?URL=http://www.sl-king.com/georestsamples/example1/rview.html> example1 <https://webmail.pac.dfo-mpo.gc.ca/exchweb/bin/redir.asp?URL=http://www.sl-king.com/georestsamples/example1/rview.html> / <https://webmail.pac.dfo-mpo.gc.ca/exchweb/bin/redir.asp?URL=http://www.sl-king.com/georestsamples/example1/rview.html> rview <https://webmail.pac.dfo-mpo.gc.ca/exchweb/bin/redir.asp?URL=http://www.sl-king.com/georestsamples/example1/rview.html> .ht <https://webmail.pac.dfo-mpo.gc.ca/exchweb/bin/redir.asp?URL=http://www.sl-king.com/georestsamples/example1/rview.html> ml <https://webmail.pac.dfo-mpo.gc.ca/exchweb/bin/redir.asp?URL=http://www.sl-king.com/georestsamples/example1/rview.html>
No map shows up for me for some reason/
thanks
Brad Mason M.R.M.
Senior Habitat Inventory Biologist
Habitat Protection and Sustainable Development
Oceans, Habitat and Enhancement Branch
Fisheries and Oceans Canada
200 401 Burrard St.,
Vancouver, B.C. Canada  V6C 3S4
tel: (604)666-7015
fax: (604)666-0417
email: Brad.Mason at dfo-mpo.gc.ca
Director, Community Mapping Network
www.cmnbc.ca <http://www.cmnbc.ca/>
From: Haris Kurtagic [via OSGeo.org] [mailto:ml-node+4594141-1580677563-210184 at n2.nabble.com]
Sent: Thu 18/02/2010 12:26 PM
To: Mason, Brad
Subject: Re: GeoREST 1.0 Released!
Yes, that is exactly what we are doing with GeoREST.
There is working example with Sheboygan data, when you unpack GeoREST. As it says in installation notes http://code.google.com/p/georest/wiki/Installation you can run it and try quickly with build-in http server. You can try it even without MapGuide  in such case there will be no image but you can view/edit data as vector trough OL and GeoREST OL layer.
Also, on our web there is basic sample:
http://www.sl-king.com/ <http://www.sl-king.com/georestsamples/example1/rview.html> georestsamples <http://www.sl-king.com/georestsamples/example1/rview.html> / <http://www.sl-king.com/georestsamples/example1/rview.html> example1 <http://www.sl-king.com/georestsamples/example1/rview.html> / <http://www.sl-king.com/georestsamples/example1/rview.html> rview <http://www.sl-king.com/georestsamples/example1/rview.html> .ht <http://www.sl-king.com/georestsamples/example1/rview.html> ml <http://www.sl-king.com/georestsamples/example1/rview.html>
When you zoom  in , you can edit parcels, buildings. When you select parcel/building on left you will get option to click edit which will be bring html form trough which you can edit data.
All this is driven trough http and html templates, you don't need any coding to do basic stuff.
What is missing right now is security for editing.
We are working on real project where edits needs to be allowed for authenticated users only, when we finish it it will be part of GeoREST.
Haris
On Thu, Feb 18, 2010 at 8:55 PM, BradM <[hidden email] <http://n2.nabble.com/user/SendEmail.jtp?type=node&node=4594141&i=0> > wrote:
	Hello, Â could you please give me an example using GeoREST, Â where users can
	digitize a point, line or polygon, and then bring up an html data entry
	form. Â  Â The user can then add data to the data entry form and send it and
	the associated coordinates to a database. Â The database can then be searched
	and reports created.. Is this a good use of GeoREST?
	thanks
	View this message in context: http://n2.nabble.com/GeoREST-1-0-Released-tp4212935p4593986.html
	mapguide-users mailing list
	[hidden email] <http://n2.nabble.com/user/SendEmail.jtp?type=node&node=4594141&i=1>
	http://lists.osgeo.org/mailman/listinfo/mapguide-users
[hidden email] <http://n2.nabble.com/user/SendEmail.jtp?type=node&node=4594141&i=2>
View message @ http://n2.nabble.com/GeoREST-1-0-Released-tp4212935p4594141.html
To unsubscribe from Re: GeoREST 1.0 Released!, click here < (link removed) > .
View this message in context: http://n2.nabble.com/GeoREST-1-0-Released-tp4212935p4594472.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20100218/489cdc40/attachment.html
