[mapguide-users] Point (symbol) not scaling larger when zooming in
kelll kellieharrisson at sierrasystems.com
Mon Mar 22 19:26:14 EDT 2010
I have provided 2 screen shots.
One at scale 1:29471 showing the green triangle as my point symbol.
One at scale 1:2587 showing the green triangle at the same size. I would
expect this green triangle to scale bigger as I zoom in closer as it would
in other GIS viewers.
I see in Maestro that I can add multiple layer styles setting the scale
range and changing the symbol to be larger for each scale range, but I just
want to make sure there is no other options.
I don't understand why the line layer zooms correctly (when zooming in, the
line scales bigger) and the point layer doesn't scale.
http://n2.nabble.com/file/n4781273/Triangle_zoomed_out.jpg
http://n2.nabble.com/file/n4781273/Triangle_zoomed_in.jpg
View this message in context: http://n2.nabble.com/Point-symbol-not-scaling-larger-when-zooming-in-tp4781273p4781273.html
