[mapguide-users] Point (symbol) not scaling larger when zooming in
Georges KACOU georges.kacou at genesis.ci
Tue Mar 23 08:54:01 EDT 2010
It seems that you specified the symbol's size in device units (in
Maestro, Size context : Device space). Use "Map space" instead for the
size context of your symbol.
kelll a écrit :
> I have provided 2 screen shots.
> One at scale 1:29471 showing the green triangle as my point symbol.
> One at scale 1:2587 showing the green triangle at the same size. I would
> expect this green triangle to scale bigger as I zoom in closer as it would
> in other GIS viewers.
> I see in Maestro that I can add multiple layer styles setting the scale
> range and changing the symbol to be larger for each scale range, but I just
> want to make sure there is no other options.
> I don't understand why the line layer zooms correctly (when zooming in, the
> line scales bigger) and the point layer doesn't scale.
> http://n2.nabble.com/file/n4781273/Triangle_zoomed_out.jpg
> http://n2.nabble.com/file/n4781273/Triangle_zoomed_in.jpg
