[mapguide-users] Re: Mag Guide setup on II7 2008 Server Issue, Please help
Steve G steve.golden at morganhill.ca.gov
Thu May 6 11:52:57 EDT 2010
Tori...glad you got it working.  To respond to your questions just in case
anyone else is reading this post and has the same problems, I installed MGOS
2.1 using the manual configuration and then followed all the instructions on
the wiki page (not the PDF).  I had the security problem a while back on a
test server when I changed my login password and forgot to change the
authentication in IIS...classic mistake.
-Steve
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Mag-Guide-setup-on-II7-2008-Server-Issue-Please-help-tp5010394p5014976.html
