[mapguide-users] RE: Mapguide is selecting invisible
Ivan Miličević Ivan.Milicevic at supranet.hr
Thu Oct 21 21:54:11 EDT 2010
Hello,
I have worked out it today. It was simple, a wrong field for indetity has been set. Everything works just fine now.
Thnak you anyway :)
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Martin Morrison
Sent: Thursday, October 21, 2010 9:46 PM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] RE: Mapguide is selecting invisible
If you run "select geom from whatevertable where geom.STIsValid() <> 1" first, you will find out whether you have a problem or not.
Martin Morrison
Application Engineer
Engineering Design Systems, Inc.
3780 Peters Creek Rd Ext SW
Roanoke, VA  24018
540.345.1410
gis.edsi.com
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Srecko Lipovsek
Sent: Thursday, October 21, 2010 2:45 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] RE: Mapguide is selecting invisible
Did you try update geometry in database with .MakeValid()?
We have also problems with this and simple update statement always correct the problem ...
UPDATE tName set geom = geom.MakeValid()
Srecko Lipovsek, BSc Civil Engineer
Kaliopa d.o.o.: Ljubljana, Slovenija
WWW: www.Kaliopa.si<http://www.Kaliopa.si?by-user=t> | www.iObcina.si<http://www.iObcina.si?by-user=t> | gis.iObcina.si<http://gis.iObcina.si?by-user=t> | www.iSlovenija.si<http://www.iSlovenija.si?by-user=t> | www.iKomunala.si<http://www.iKomunala.si?by-user=t>
View this message in context: RE: Mapguide is selecting invisible<http://osgeo-org.1803224.n2.nabble.com/Mapguide-is-selecting-invisible-tp5650775p5659820.html>
Sent from the MapGuide Users mailing list archive<http://osgeo-org.1803224.n2.nabble.com/MapGuide-Users-f1803227.html> at Nabble.com.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20101022/d26cc7b0/attachment.html
