[mapguide-users] Re: Mapguide won't display all features from King Oracle connections
Haris Kurtagic haris at sl-king.com
Tue Oct 26 13:32:13 EDT 2010
I forgot a bit, but haven't I fixed some gtype 4 after you send me
test geometries ?
If there are gtype 4 geometries you think King.Oracle can't read, send
them please, I will check it
Haris
On Tue, Oct 26, 2010 at 1:37 PM, djonio <DJonio at miami-airport.com> wrote:
> Howdy,
> MGOS 2.1
> KingOra 8.19
> We use KingOracle a bunch and our only issue is and has been mixed
> multi-geometries(collections - sdo_gtype : 4) and circles (1,1003,4). We
> have no issues at all on the FDO/Mg input input side and it appears to me
> that it is an issue with MG rendering. Circles have been a real issue in
> that MG throws one of those "failed to stylize" errors and just gives up.
> The fix for me is to use (1,1005,1, 1,2,2)'s as a couple arcs instead of
> circles. The gtype 4's don't produce the failed to stylize error but they
> silently do not render.
> Since the workaround for circles is relatively easy and the need for the
> collection type geometry is rare for me I have not persued the issue.
> However, if someone wishes to fix this I can produce some EPSG:2236(FL83-EF)
> geometries for test.
> r,
> dennis
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Mapguide-won-t-display-all-features-from-King-Oracle-connections-tp5657213p5674262.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
