[mapguide-users] built in search tool question
jtby jbrosowsky at geo-comm.com
Thu Sep 9 10:07:06 EDT 2010
Hi -
I have a added the built in search tool to my layout using maestro to allow
the user to search for an attribute in a single field.  I am using the
ajaxviewer.  Now my user can pick the search tool, type in parcel ID number
to search for, press the Find button, the search results in the task pane
appear, the user can pick one, and the map zooms to that location, works
great.  But I have two problems:
- when the user clicks on a search result to zoom to that feature on the
map, a message box pops up that says "No response from feature selection
request".  I am not sure what that means, but I am guessing it is describing
the issue causing my problem:
- when I click OK on the message box, the map does zoom to the correct
location as expected, and there is a message in the status bar at the bottom
of the page that says "1 Parcel selected" as expected, but the parcel zoomed
to on the map is not highlighted.  I would expect it to be highlighted.
Do you have any ideas?
Thx!
View this message in context: http://osgeo-org.1803224.n2.nabble.com/built-in-search-tool-question-tp5514566p5514566.html
