[mapguide-users] Re: Mapagent FCGI Not Found
GIS4U johnniegis at gmail.com
Tue Dec 20 14:43:18 EST 2011
Thanks for sharing your detailed solution.  Everyone of them posted up here
may help someone in the future.
On Tue, Dec 20, 2011 at 11:22 AM, John Grego <johng at vtnnv.com> wrote:
> My problem is now solved.
> Although I’ve tried everything contained in the following solution before,
> I
> believe the thoroughness and sequencing of the steps was the key to my
> current success in configuring IMS 2012 to run on IIS 7.5, Windows 2008
> Server R2 (64-bit).
> 1.  Move the contents of the Default Web Site (c:\inetpub\wwwroot) to a
> temporary location.
> 2.  Remove IIS 7.5 and the c:\inetpub directory contents.
> 3.  Uninstall the IMS web server extensions and remove the directory; in my
> case:  C:\Program Files\Autodesk\Autodesk Infrastructure Web Server
> Extension 2012
> 4.  Reboot the server.
> 5.  Add the Web Server (IIS) role with the default services, and include
> all
> of the Application Development services, i.e., ASP.NET, CGI, etc.
> 6.  Install Microsoft.NET Framework V4.0.30319.  At one time I had
> successfully configured IMS to run with Framework V2.0.50727, but I decided
> to try V4.0 because it was referenced by someone in another thread.
> 7.  Restore the contents of the Default Web Site that were moved in step 1.
> 8.  I reinstalled the web server extensions as I’ve done on numerous
> occasions, using the instructions contained here:
> http://wikihelp.autodesk.com/Infr._Map_Server/enu/2012/Help/New/0000-Installa0/0008-Installa8/0011-Configur11/0014-Configur14
> 9.  I created an application pool for my IMS applications, based on the
> V4.0
> .NET Framework Version in Integrated Managed Pipeline Mode.    I also set
> the Enable 32-Bit Applications setting to False, as Hans suggested earlier.
> It may have been possible to achieve the same results without completely
> removing everything, but after various combinations of settings that did
> not
> work, this method finally helped me get IMS up and running again.  I hope
> others may find this information useful.
> Regards,
> -John
> John Grego
> VTN
> http://www.vtnnv.com
> http://osgeo-org.1803224.n2.nabble.com/Mapagent-FCGI-Not-Found-tp1804128p7112984.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20111220/d8d7f8aa/attachment.html
