[mapguide-users] Re: MGOS 2.2 RC4 64bit - problem with references
Trevor Wekel trevor_wekel at otxsystems.com
Mon Mar 21 19:58:08 EDT 2011
Also check your "Multi-Targeting" settings.  The Web Extensions are built with .Net 2.0.  http://msdn.microsoft.com/en-us/library/bb398197.aspx
If you are running on a "newer" machine you may also have to install .NET 3.5 Service Pack 1 to get .NET 2.0.  It is possible that a fresh install of Windows with VS 2010 will not have .NET 2.0 installed.  I don't have a new Windows 7 box around to try this out at the moment.
Regards,
Trevor
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: March 21, 2011 5:51 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Re: MGOS 2.2 RC4 64bit - problem with references
Try setting your build platform to x64.
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/MGOS-2-2-RC4-64bit-problem-with-references-tp6193359p6194442.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
