[mapguide-users] Re: 64bit dlls not working
Trevor Wekel trevor_wekel at otxsystems.com
Wed May 18 12:42:31 EDT 2011
Are you using Autodesk IMS 2012? The build number "2.3.0.4202" would seem to indicate MapGuide 2.3 and not MapGuide 2.2.  The version number for the MapGuide Open Source 2.2 release is 2.2.0.5703.  Perhaps there are some old dlls in a .Net "bin" directory somewhere.
One issue I have been made aware of is that previous MapGuide version marked the 64 bit .Net libraries as "any platform" so 32 bit .Net web app compilation against the 64 bit .Net Web Extensions may have worked in the past.  The web app would probably kick out if it is was run in a 32 bit .Net environment since the C++ libraries are 64 bit.  I do not believe this is the issue you are seeing.
Regards,
Trevor
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of frosty1_4me
Sent: May 18, 2011 10:29 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Re: 64bit dlls not working
I've tried moving this to VS2010 using the 32bit dlls with little success.
There is some kind of conflict happening somewhere, and I have no ideal
whats causing it.
I get a lot of the errors about being unable to load an assembly as I
orginally posted and with the 32bit version I get alot of these errors as
well:
Type 'OSGeo.MapGuide.MgException' in assembly 'MapGuideDotNetApi,
Version=2.3.0.4202, Culture=neutral, PublicKeyToken=null' has been forwarded
to assembly 'OSGeo.MapGuide.Foundation'. Either a reference to
'OSGeo.MapGuide.Foundation' is missing from your project or the type
'OSGeo.MapGuide.MgException' is missing from assembly
I'm not missing the dlls.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/64bit-dlls-not-working-tp6374501p6378446.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
