[mapguide-users] MS Access connection lost during 2.1 to 2.2 migration
Gordon McKenzie gord.mckenzie at canam.com
Wed Sep 7 17:40:35 EDT 2011
Is this an ODBC 32bit/64bit driver issue?  If you are using Mapguide 64 bit
and your DB connection is through ODBC I believe you will need 64 bit ODBC
drivers such as those that come with Office 2010 64 Bit.
Gord McKenzie
GIS Coordinator, GeoSpatial Solutions
can-am geomatics corp.
900, 340 12th Avenue SW
Calgary, Alberta
P: 403.269.8887 F: 403.269.8497
www.canam.com
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Ward Kilby
Sent: September-07-11 3:25 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] MS Access connection lost during 2.1 to 2.2
migration
I have a number of MS Access databases that I have connected to a MGOS 2.1
site and have been working fine. I recently packaged the site and loaded it
onto a MGOS 2.2 site, on the same machine. Most everything worked well but I
can not connect to the Access databases from the 2.2 site. The connections
still work fine from the 2.1 site.
I am using Maestro 3.5, on a Win 2003 server, 64 bit machine.
I get a "559 MgFdoException RDBMS: No current open database." error when I
try testing the connections.
I have tried using the older FDO etc with no luck.
Any suggestions?
View this message in context:
http://osgeo-org.1803224.n2.nabble.com/MS-Access-connection-lost-during-2-1-
to-2-2-migration-tp6769528p6769528.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
