[mapguide-users] MS Access connection lost during 2.1 to 2.2 migration
GIS4U johnniegis at gmail.com
Wed Sep 7 17:59:49 EDT 2011
Hi Ward,
I am able to read MS Access files (.mdb) using both "Unmanaged" and "DSN"
Connection methods in MG 2.2 (64 bit) and Maestro 3.5 on Windows 7 Pro (64
bit).  I believe that I had to install the 64 bit ODBC drivers in the past
though so that may be what is allowing it to work.  Maestro does prompt to
see if I want to use the "Office 2010 Drivers".
Hope that helps,
Jonathon
On Wed, Sep 7, 2011 at 2:24 PM, Ward Kilby <wkilby at telus.net> wrote:
> Hi,
> I have a number of MS Access databases that I have connected to a MGOS 2.1
> site and have been working fine. I recently packaged the site and loaded it
> onto a MGOS 2.2 site, on the same machine. Most everything worked well but
> I
> can not connect to the Access databases from the 2.2 site. The connections
> still work fine from the 2.1 site.
> I am using Maestro 3.5, on a Win 2003 server, 64 bit machine.
> I get a "559 MgFdoException RDBMS: No current open database." error when I
> try testing the connections.
> I have tried using the older FDO etc with no luck.
> Any suggestions?
> http://osgeo-org.1803224.n2.nabble.com/MS-Access-connection-lost-during-2-1-to-2-2-migration-tp6769528p6769528.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20110907/32929927/attachment.html
