[mapguide-users] Re: Fusion layout is blank
Homan, Thomas thoman at co.gila.az.us
Mon Sep 19 16:03:39 EDT 2011
If you create a map matching your UTM projection do things work? I'm going to guess that you're using PseudoMercator to support the 'big 3' basemaps.
What happens if you reproject your datasets to PM other than the expected performance improvement because OTF reprojection is not being utilized. Along that same thread, did you save/override the coordinate systems of each layer definition rather than letting MG attempt to figure things out on its own?
Just some obvious but random thoughts
-tom
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of elliott17
Sent: Monday, September 19, 2011 12:50 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Re: Fusion layout is blank
I saved my map as PseudoMercator:
PROJCS["WGS84.PseudoMercator",GEOGCS["LL84",DATUM["WGS84",SPHEROID["WGS84",6378137.000,298.25722293]]
My original layers were in UTM.
I am trying to view the URL from maestro with no success.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Fusion-layout-is-blank-tp6802416p6809849.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
