[mapguide-users] Re: Fusion layout is blank
Michael Adair madair at dmsolutions.ca
Mon Sep 19 16:31:05 EDT 2011
This may or may not be the issue with the missing layer but the MG
definition of "PseudoMercator" is not the same as the "big 3/Google
mercator/spherical mercator" because the one listed below is not a
sphere - for it to be spherical, the 3rd param in the SPHEROID text must
be a 0 (zero).  See  http://spatialreference.org/ref/epsg/3785/
If you have a Google base layer and try to overlay "PseudoMercator" on
top it's not going to line up properly.
Mike
On 19/09/2011 4:03 PM, Homan, Thomas wrote:
> If you create a map matching your UTM projection do things work? I'm going to guess that you're using PseudoMercator to support the 'big 3' basemaps.
> What happens if you reproject your datasets to PM other than the expected performance improvement because OTF reprojection is not being utilized. Along that same thread, did you save/override the coordinate systems of each layer definition rather than letting MG attempt to figure things out on its own?
> Just some obvious but random thoughts
> -tom
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of elliott17
> Sent: Monday, September 19, 2011 12:50 PM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] Re: Fusion layout is blank
> I saved my map as PseudoMercator:
> PROJCS["WGS84.PseudoMercator",GEOGCS["LL84",DATUM["WGS84",SPHEROID["WGS84",6378137.000,298.25722293]]
> My original layers were in UTM.
> I am trying to view the URL from maestro with no success.
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Fusion-layout-is-blank-tp6802416p6809849.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
