[mapguide-users] RE: Fusion Task Pane without session variable
Michael Adair madair at dmsolutions.ca
Wed Sep 21 13:09:56 EDT 2011
If you are doing development work, it is highly recommended that you use
the fusion.js file (not a single file version) which pulls in all
required files based on the contents of the AppDef, also so that you can
edit the original files and not the assembled single file version.  Once
your site is ready to go into production, you can then build a single
file version of fusion, see http://trac.osgeo.org/fusion/wiki/ANTBuildSystem
Mike
On 21/09/2011 1:02 PM, Greg wrote:
> I am very new to Mapguide and especially Fusion so I think there is something
> important I have missed here.  The following line is included in my
> index.html page.
> Please correct me if I'm wrong;  the code for TaskPane.js is included in
> fusionSF-compressed.js and that is where I need to make the change suggested
> by Brian and not in the TaskPane.js.  Or is it possible to make the change
> in TaskPane.js and then include
> in index.html?
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Fusion-Task-Pane-without-session-variable-tp6801587p6816911.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
