[mapguide-users] Re: sample 'property_report.php' as a custom command
GordonL gordon.luckett at arrowgeomatics.com
Mon Sep 26 09:36:05 EDT 2011
The Property Report is a custom report for that particular data set.  You
would have to write your own.
Try out this generic one:
All you need is to launch the InvokeURL (Basic and Fusion) to run it.
<body onload="focus()">
<?php
$configFilePath = "C:\Program
Files\OSGeo\MapGuide\Web\www\webconfig.ini\webconfig.ini";
$mgSessionId = ($_SERVER['REQUEST_METHOD'] == "POST")? $_POST['SESSION']:
$_GET['SESSION'];
$mapName = ($_SERVER['REQUEST_METHOD'] == "POST")? $_POST['MAPNAME']:
$_GET['MAPNAME'];
// Initialize the Web Extensions and connect to the Server using
// the Web Extensions session identifier stored in PHP
// session state.
MgInitializeWebTier($cofigFilePath);
$userInfo = new MgUserInformation($mgSessionId);
$siteConnection = new MgSiteConnection();
$siteConnection->Open($userInfo);
$resourceService = $siteConnection->CreateService(0);
$featureService = $siteConnection->CreateService(2);
$queryOptions = new MgFeatureQueryOptions();
$map = new MgMap($siteConnection);
$map->Open($mapName);
        $selection = new MgSelection($map);
		$selection->Open($resourceService, $mapName);
        $selectedLayers = $selection->GetLayers();
		$numberLayers = $selectedLayers->GetCount();
        $wktReaderWriter = new MgWktReaderWriter();  //for getPropertyValue
        $agfReaderWriter = new MgAgfReaderWriter();  // for getPropertyValue
		//Create table
		echo '<table>';
        for ($i = 0; $i < $numberLayers; $i++)
           $layer = $selectedLayers->GetItem($i);
    	   $layerName = $layer->GetName();
           $layerClassName = $layer->GetFeatureClassName();
           $featureReader =  $selection->GetSelectedFeatures($layer,
$layerClassName, false);
			$firstOne = true;
			 echo '<tr><td colspan=3>*Layer: ' .$layerName .'*</td></tr>';
		 while ($featureReader->ReadNext())
				 $propCount = $featureReader->GetPropertyCount();
                 for($j=0; $j<$propCount; $j++)
                   if($j ==0)
						echo '<tr>';
 					$propertyName = $featureReader->GetPropertyName($j);
                     $boolVal = $featureReader->IsNull($propertyName);
                     if ($boolVal)
                          continue;
                     }// end if
                     $propertyType =
$featureReader->GetPropertyType($propertyName);
                     $propertyValue =
getPropertyValue($featureReader,$propertyType,$propertyName);
                     //echo '<tr><th align=right>' . $propertyName .
'</th><td> ' . $propertyValue . '</td></tr>';
					if($firstOne)
						echo  '<td valign=top>*' . $propertyName . '*<br>' . $propertyValue .
'</td>';
					else
						echo  '<td>' .  $propertyValue . '</td>';
				$firstOne=false;
             } //end loop over features
        } //end loop over layer
//-------------------------getPropertyValue
BEGINS---------------------------
  * Gets data for a layer property
function getPropertyValue(&$featureReader, $propertyType, $propertyName)
    global $agfReaderWriter;
    global $wktReaderWriter;
    switch ($propertyType)
        case 0 :
            break;
          case 1 :
                 $val = $featureReader->GetBoolean($propertyName);
                 $valStr = printBoolean($val);
                 break;
          case 2 :
                 $val = $featureReader->GetByte($propertyName);
                 break;
          case 3 :
                 $val = $featureReader->GetDateTime($propertyName);
				 $val = $val->ToString();
                 break;
          case 4 :
                 $val = $featureReader->GetSingle($propertyName);
                 break;
          case 5:
                 $val = $featureReader->GetDouble($propertyName);
                 break;
          case 6 :
                 $val = $featureReader->GetInt16($propertyName);
                 break;
          case 7 :
                 $val = $featureReader->GetInt32($propertyName);
                 break;
          case 8 :
                 $val = $featureReader->GetInt64($propertyName);
                 break;
          case 9 :
                 $val = $featureReader->GetString($propertyName);
                 break;
          case 10 :
                 //fwrite($logFileHandle, "$propertyName is blob");
                 break;
          case 11 :
                 break;
          case 12 :
                 $val = $featureReader->GetFeatureObject($propertyName);
                break;
          case 13 :
                 break;
          case 14 :
                 $val = $featureReader->GetRaster($propertyName);
                 break;
       }// end switch
       return $val;
View this message in context: http://osgeo-org.1803224.n2.nabble.com/sample-property-report-php-as-a-custom-command-tp6830978p6831885.html
