[mapguide-users] FDO PostgreSQL/PostGIS provider on 64bit
Pedro Venâncio pedrongvenancio at yahoo.com
Tue Sep 27 06:22:55 EDT 2011
Hello,
I have MapGuide OS 2.2 with bundled setup and PHP on a Windows 7 Pro 64bit machine, and when I try to connect through FDO PostgreSQL/PostGIS Provider, it show me this error:
System.Exception: O servidor remoto devolveu um erro: (559) MgFdoException.:
An exception occurred in FDO component.
Unable to load the FDO Provider: (null)
 ---> System.Net.WebException: O servidor remoto devolveu um erro: (559) MgFdoException.
   em System.Net.HttpWebRequest.GetResponse()
   em OSGeo.MapGuide.MaestroAPI.HttpServerConnection.OpenRead(String req) em d:\Workspace\maestro-trunk\OSGeo.MapGuide.MaestroAPI.Http\HttpServerConnection.cs:line 1219
   --- Fim do rastreio da pilha de excepção interna ---
   em OSGeo.MapGuide.MaestroAPI.HttpServerConnection.OpenRead(String req) em d:\Workspace\maestro-trunk\OSGeo.MapGuide.MaestroAPI.Http\HttpServerConnection.cs:line 1233
   em OSGeo.MapGuide.MaestroAPI.HttpServerConnection.GetProviderCapabilities(String provider) em d:\Workspace\maestro-trunk\OSGeo.MapGuide.MaestroAPI.Http\HttpServerConnection.cs:line 1659
   em Maestro.Base.Editor.FsEditorOptionPanel.Bind(IEditorService service) em d:\Workspace\maestro-trunk\Maestro.Base\Editor\FsEditorOptionPanel.cs:line 60
   em Maestro.Base.Editor.FeatureSourceEditor.Bind(IEditorService service) em d:\Workspace\maestro-trunk\Maestro.Base\Editor\FeatureSourceEditor.cs:line 63
   em Maestro.Base.Editor.EditorContentBase.set_EditorService(IEditorService value) em d:\Workspace\maestro-trunk\Maestro.Base\Editor\EditorContentBase.cs:line 81
   em Maestro.Base.Services.OpenResourceManager.Open(IResource res, IServerConnection conn, Boolean useXmlEditor, ISiteExplorer siteExp) em d:\Workspace\maestro-trunk\Maestro.Base\Services\OpenResourceManager.cs:line 164
   em Maestro.Base.Services.OpenResourceManager.Open(String resourceId, IServerConnection conn, Boolean useXmlEditor, ISiteExplorer siteExp) em d:\Workspace\maestro-trunk\Maestro.Base\Services\OpenResourceManager.cs:line 219
System.NullReferenceException: A referência de objecto não foi definida como uma instância de um objecto.
   em Maestro.Base.Commands.NewItemCommand.Run() em d:\Workspace\maestro-trunk\Maestro.Base\Commands\NewItemCommand.cs:line 64
   em ICSharpCode.Core.WinForms.MenuCommand.OnClick(EventArgs e)
   em System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e)
   em System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)
   em System.Windows.Forms.ToolStripItem.FireEventInteractive(EventArgs e, ToolStripItemEventType met)
   em System.Windows.Forms.ToolStripItem.FireEvent(EventArgs e, ToolStripItemEventType met)
   em System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)
   em System.Windows.Forms.ToolStripDropDown.OnMouseUp(MouseEventArgs mea)
   em System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
   em System.Windows.Forms.Control.WndProc(Message& m)
   em System.Windows.Forms.ScrollableControl.WndProc(Message& m)
   em System.Windows.Forms.ToolStrip.WndProc(Message& m)
   em System.Windows.Forms.ToolStripDropDown.WndProc(Message& m)
   em System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   em System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   em System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
I have exactly the same configuration but on a Windows 7 Ultimate 32bit machine, and everything works fine.
Note that I do not have PostgreSQL installed on any of them, I am accessing a database on Linux.
Can this be a 64bit problem?
Thank you very much!
Best regards,
Pedro Venancio
