[mapguide-users] Thematic maps on Non Spatial Data
Martin Morrison martin.morrison at edsi.com
Fri Aug 10 09:07:12 PDT 2012
Just a couple of questions for you so you can maybe rephrase your question.
If you do not want to do join tables, then how will the non-spatial data ever be represented on a map?  Do they have an XY column?
Martin Morrison
Application Engineer
Engineering Design Systems, Inc.
3780 Peters Creek Rd Ext SW
Roanoke, VA  24018
540.345.1410
gis.edsi.com
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of nandankishorks
Sent: Friday, August 10, 2012 1:29 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Thematic maps on Non Spatial Data
Dear All,
I need to create the thematic map on a polygon layer. But the data is not available in the layer; I am using Postgres database for that. It means I need to create the themes on layer using non spatial data.
Also I don't want to JOIN tables(Spatial table to join Non-Spatial table).
Please give me any hint to this, it is very urgent.
-Nandan
View this message in context: http://osgeo-org.1560.n6.nabble.com/Thematic-maps-on-Non-Spatial-Data-tp4994300.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
