[mapguide-users] Maestro 5.0b. the extent of DWF file can't be parsed automatically?
Zac Spitzer zac.spitzer at gmail.com
Wed Nov 7 17:58:11 PST 2012
I'm pretty sure dwfx isn't currently supported by mapguide?
On Thu, Nov 8, 2012 at 11:49 AM, carls <carlshe at 163.com> wrote:
> Hi, Jackie,
>    Thank you for your great contribution to MG and Maestro.
>    I unpack two different types of dwf file, one is the older version
> (*.dwf), and another is the newer version (*.dwfx).
>    I found *.dwf has no *.pia within it, and *.dwfx exactly has a *.pia
> file. But both files have the descriptor.xml which contains the
> 'ePlot:Paper', that defines the clip of the paper used for drawing.
>    But to my suprise, Maestro doesn't accept a *.dwfx file to create a
> drawing source. *.dwf is accepted, but because no *.pia file within it, so
> I
> guess, that's just why no extent parsed for it automatically.
>    Maybe you used the newer toolkit to parse the older file?
>    Just for your reference. Because I have only two files respectively for
> the older and newer versions of dwf format, I can't give more information
> about it now.
>    Thanks again!
> http://osgeo-org.1560.n6.nabble.com/Maestro-5-0b-the-extent-of-DWF-file-can-t-be-parsed-automatically-tp5014170p5014685.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
+61 405 847 168
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20121108/e01c0791/attachment.html>
