[mapguide-users] I need advice on grid data gdal/vrt and mapguide
Jamo adam.jamison at portbris.com.au
Wed Nov 28 19:49:09 PST 2012
Say I have some grid data I can retreive in the form of
x,y,z
where x and y are true GDA MGA-56 coordinates and z is a positive or
negative decimal value....
How would I take this data and display it in mapguide? So far I have tried
using Saga to produce grid files for them then prepare a vrt file and show
them using that, however I'm finding setting it up to accept transparency
difficult (where there is no data -99999 the grid should not display
anything)
None of the GridLayerDefinition settings in the Layerdefinition seem to work
Some example data:
*VRT file 4 bands RGB and true height.*
Can I just supply mapguide the sdat file and style completely in mapguide?
*Grid Layer Definition:*
Any help would be much appreciated, despite what my signature says this is
for Mapguide 2.4 stable release on windows server 2008 R2 SP1 64bit
I have managed to remove all hillshade settings and surface settings and
render greyscale surface however I still can't get the transparency to
work... I can load the vrt in saga and it displays
Cheers
Adam
MapGuide Maestro 5.0b
MapGuide Opensource 2.2.0.5703
Fusion, PHP, Apache
Windows Server 2008 64bit
View this message in context: http://osgeo-org.1560.n6.nabble.com/I-need-advice-on-grid-data-gdal-vrt-and-mapguide-tp5019464.html
