[mapguide-users] Maestro 4.0.4 - Cannot change WMS from PNG to JPG
Hans Milling hm at geograf.dk
Wed Nov 28 23:43:08 PST 2012
Hi All
Using Maestro 4.0.4 and MGOS2.2 I have added a WMS feature source, and using
the default PNG works fine. However it's an orthofoto and jpeg is a bit
faster. I then click Advanced, Image format and and change the type to JPG.
But when I save the feature source I get the following error:
System.Exception: The remote server returned an error: (559)
MgUnclassifiedException.:
Problem:\nThe application encountered a problem and could not finish the
operation you just requested properly.\n\nSolution:\nIf it\'s the first time
you met this problem, try again or restart the application / session;
otherwise, describe the steps to reproduce this problem to the server
administrator for suggestions.
 ---> System.Net.WebException: The remote server returned an error: (559)
   at System.Net.HttpWebRequest.GetResponse()
   at OSGeo.MapGuide.MaestroAPI.HttpServerConnection.OpenRead(String req) in
c:\Program Files (x86)\Jenkins\jobs\Maestro
4.0.x\workspace\OSGeo.MapGuide.MaestroAPI.Http\HttpServerConnection.cs:line
1221
   --- End of inner exception stack trace ---
1237
   at
OSGeo.MapGuide.MaestroAPI.HttpServerConnection.DescribeFeatureSource(String
resourceID) in c:\Program Files (x86)\Jenkins\jobs\Maestro
668
   at
OSGeo.MapGuide.ObjectModels.FeatureSource.FeatureSourceExtensions.Describe(IFeatureSource
fs) in c:\Program Files (x86)\Jenkins\jobs\Maestro
4.0.x\workspace\OSGeo.MapGuide.MaestroAPI\ObjectModels\FeatureSourceInterfaces.cs:line
486
   at Maestro.Editors.FeatureSource.ExtensionsCtrl.OnResourceSaved(Object
sender, EventArgs e) in c:\Program Files (x86)\Jenkins\jobs\Maestro
4.0.x\workspace\Maestro.Editors\FeatureSource\ExtensionsCtrl.cs:line 149
   at System.EventHandler.Invoke(Object sender, EventArgs e)
   at Maestro.Editors.ResourceEditorServiceBase.OnSaved() in c:\Program
4.0.x\workspace\Maestro.Editors\ResourceEditorServiceBase.cs:line 423
   at Maestro.Editors.ResourceEditorServiceBase.SaveAs(String resourceID) in
4.0.x\workspace\Maestro.Editors\ResourceEditorServiceBase.cs:line 251
   at Maestro.Base.Commands.SaveResourceAsCommand.Run() in c:\Program Files
4.0.x\workspace\Maestro.Base\Commands\SaveResourceAsCommand.cs:line 60
   at Maestro.Base.Commands.SaveResourceCommand.Run() in c:\Program Files
4.0.x\workspace\Maestro.Base\Commands\SaveResourceCommand.cs:line 39
   at ICSharpCode.Core.WinForms.ToolBarCommand.OnClick(EventArgs e)
   at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e)
   at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)
   at System.Windows.Forms.ToolStripItem.FireEventInteractive(EventArgs e,
ToolStripItemEventType met)
   at System.Windows.Forms.ToolStripItem.FireEvent(EventArgs e,
   at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)
   at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons
button, Int32 clicks)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
   at System.Windows.Forms.ToolStrip.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg,
IntPtr wparam, IntPtr lparam)
Should I file a ticket or is there a known workaround? (I can edit the XML
manually, but after saving and either testing or using the feature source
the MapGuide server throws the same error).
Best regards
  Hans Milling...
View this message in context: http://osgeo-org.1560.n6.nabble.com/Maestro-4-0-4-Cannot-change-WMS-from-PNG-to-JPG-tp5019493.html
